Before you just go out and buy the cheapest hose you can...
1. Do you really need braided hose?
2. What fuel are you using?
3. Does the hose you are planning to buy have good and well priced fittings compatibility.
At the end of the day you'll end up spending thousands on hose and fittings....
Cheers J.
  • Like 1
I'd have to disagree Badgaz,,,I've seen heaps of cars running it and not one has exploded into flames. I think if it's done properly there will be no problems at all.
I've just converted my radical to that system(not steel outer braided though) and I feel a lot safer than using simple hose clamps.
Adz check out these guys,,,I buy all my hoses and fittings from them and they are cheaper than earls ect.
www.phenixindustries.com.au
Cheers
Neil.
There have been extensive discussions on the various braided line options over at PF. I would recommend a search over there (use google to do the site search - like most forums in the inbuilt search sucks donkey dick). Mush solid info over there from the MANY people who use the stuff all the time.
Am I the only one who has read heaps of threads and been told from people about pin holes in the cheap braid? It could be a case of, the people I heard it from are in bed with the well known brands. But, I'd prefer to be safe than sorry.
There are some really nice attachments for fuel braid, like the filter. But at the end of the day, it's a lot of money for something cheap that can go wrong.
I upgraded my whole system to -8 speedflow 200 PTFE braided hose bypassing all the factory stuff, I figured it is carrying the only fluid in the car that can potentially burn the whole car to the ground so why on earth would you use cheap shit and risk losing the whole car just to save a few dollars, cheap eBay hoses leak and cheap eBay fitting don't seal properly when used with E85, its just not worth the risk
It really depends on your setup and wether the factory lines are big enough to flow what you need, if so the just replace the rubber hoses with E85 stuff and flush out the steel lines to get rid of any crap that's in them before the E85 cleans it into your fuel rail
I had to upgrade for my setup and due to putting a surge tank under the boot it made it easier to just new lines, as well as a 10micron screen filter and Ethanol sensor where easier to in stall as there are fittings to go straight onto them :)
  • Like 1
Its to run e85 on my track car.
my tuner suggested I do it.
also I cant really see or know how to find good stuff vs shit stuff.
Who sells it all that I can just grab it directly from tnem?
A reasonable middle of the road brand is aeroflow. They have everything you need for a good price for the quality. Just don't buy the e85 comparable pushlock hose.
Don't muck around with e85, buy Teflon lined hose or solid steel/alloy lines... everything else I've used just drys out and cracks...
My advice would be to not use stainless braid as it will chaife through anything it touches, including steel. There are other outer casings that are just as strong but don't chaife...
Good luck..
I wouldn't suggest alloy lines, unless they are anodised.
I have been running Torques UK teflon braided lines for years on my daily, without any issue. I had a lot of problems with the proflow teflon braided lines weeping from the fitting, ended up ditching them for the Torques gear, which is Aeroflow apparently.
Personally I would be running the stock fuel lines and changing the rubber hoses for modern ethanol safe hose. I have seen 450 odd kw on ethanol through the factory GTT/gtst fuel systems, only the fuel filter ever seems to be an issue.
Weldon do a 6 micron fibreglass E85 safe filter, I have a 10 micron Speedflow steel screen filter in my system, the problem with most filters is the "glue" that holds the element to the housing gets melted from the ethanol, I did find a few that would be ok before I decided to just get the Speedflow one
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
