Pretty awesome news, limited skyline support at this stage but I'm sure that will change soon for the r34 and series 2 stagea.
I'm excitedly waiting for it
http://www.nistune.com/docs/Nistune_Feature_Pack_V1.pdf
Just contacted Mat and he said r34 and stagea should be next after this current release!
Also read on his forum about using an arduino board with a flex fuel sensor rather than paying heaps for the zeitronix ethanol content gauge.
Could easily program an arduino to do it!
What's it going to cost me to set up though?
I still have my factory ECU so I still need Nistune, ethanol sensor, install and tune.
Seems like not far off 2gs to me.
Compared to all the other aftermarket reputable ecu/flex setups still half price.
So I'm looking at another $500 or so for sensors and flex tune.
Flex tunes aren't cheap, you need to tune for petrol, drain the tank then add e85, then mix it back down. It won't be an $800 install and tune.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
