Hello, I've some wierd issue with my car. I only get half boost pressure(?). I've looked over the vacuum hoses, looked after leaks around the pipes.. But it all looked good. Also checked the ECU and had no fault codes. I have no mods other then a SSQV and some aftermarket air filter.
I hope this is the right Forum part to ask this.
Thanks.
Robbin
https://www.sau.com.au/forums/topic/444319-low-boost-035-bar-rb25det/
  • Replies 40
What gauge are you using?
Looking for leaks is pretty pointless as you won't find them. You have to pressure test to find them.
Search pressure test for boost leaks on Google to see how to do it.
And put stock bov back on....
0.35bar / 5 psi is pretty much gate pressure (without the factory bleed 2-step boost controller).
As jiffo mentioned, could be either blocked lines to the bleed OR the solenoid is not plugged in/faulty.
Sorry for late answer! I was at work.
Thanks alot for all the answers. I have been trying to google the answer but still haven't found anything yet, and you all seem experienced so.. :).
I'm using an aftermarket gauge, i have tried two different ones and both showed the same. Also tested to plug in some old Apexi EBC and got the same boost with that one aswell, that one also showed how much boost i had, and i topped almost 0.4 bar. I have tried a mechanic boost controller aswell but i'm still stuck with the same boost pressure.
I'm using the high boost mod btw, by grounding the black cable that goes to the solenoid.
I'm gonna check over the hoses again and see if i connected them right. Found another picture on the internet now so i'm gonna try that first, so i'm sure i just haven't connected em all wrong.. let's just hope that it is that easy thou :).
Thanks alot for the help so far, i'll be back later today to keep you updated!
if you have an EBC.. just delete that factory boost controller setup... it's not ideal as it is set up to bleed pressure from the actuator pressure line
Um...that's what EBCs do too you know. It's just that you can change how much. The 3 port solenoid alternately connects the actuator to boost source and to vented port as the valve opens and closes on duty cycle. If you plug the vent port, EBC does very little. They are still just a glorified bleed valve (when connected to a factory style actuator anyway).
Having said that, I agree with your sentiment. Install old EBC and be happy. Although it sounds like the OP problem may in fact be a plumbing problem anyway. We shall wait and see.
OP, draw us a sketch of where the hoses come from and go to.
Edited by GTSBoy
hrms...
I always thought the way those solenoids worked was to restrict a pressurised source going to the waste gate thus stopping it from opening, once the desired pressure is reached, the EBC controller then sends a signal down to the solenoid to pulse so just the right amount of pressure to open the wastegate.
I didn't think EBC bled air, it depends how you connected the ports, happy to stand corrected
(I use a Blitz dual solenoid)
I have a Profec B which just uses the normal old MAC valve. That valve is 3 port. If it is un-powered then the NO port is connected to the COM port. NO is from the boost source, COM goes to actuator. The NC port is left open. They pretty much have to be plumbed up that way so that when the boost controller is switched off then the boost source is always connected to the actuator. Otherwise you'd have no boost control.
If you power the solenoid it connects the NC port to the COM port - ie, it vents the actuator line. The pulsing by duty cycle simply determines how much it vents. if the duty cycle is low then it spends more time connecting the boost source to the actuator. If the duty cycle is high, it spends more time venting the actuator, hence lowering the pressure in that line.
It's actually pretty crude from a control theory point of view. But it seems to work.
I've looked at the Blitz dual solenoids before and wondered where they vent the air to, given they only have 2 obvious ports.
^ great explanation as always :)
I was under the impression that worked like how I described, restrict pressure going to the actuator - appears I might have been incorrect. However, these EBCs still work better than your run of the mill turbogaids dual stage bleeder controllers.
I might take apart my dual solenoid and see if there are internal "vents" as such, the casing isn't air tight/water tight so it could just vent into the housing and escape somehow (if it similar to a MAC valve).
I just did some googling and someone else on another forum was saying exactly that - that the Blitz dual solenoids (in particular) vent internally.
http://www.imoc.co.uk/forums/viewtopic.php?t=177171&postdays=0&postorder=asc&start=20&sid=2026d2255059bb38935b584254f96051
And that also explains why the Blitz dual has a mode switch on the controller itself to choose between actuator type and external type control. On actuator mode it works the solenoid as I describe and on wastegate mode it inverts the operation of the solenoid so that increasing duty cycle increases the amount of boost allowed through to the wastegate (because externals are commonly run and plumbed differently to internals).
Thanks for all the answers, you sure know what you are talking about :). Glad to see that so many take their time and help.
I connected a hose from the intercooler pipe to a T, then to the bottom slot on the solenoid, and The other hose from the T to the wastegate. Then i connected a hose from the top slot on the solenoid to the pipe under the intercooler pipe (recycling pipe?)
Still Low boost, I'm at work till late tonight, so I guess I'll try to plug in the ebc if i get some time over (I'm running stock solenoid now).
Will make a better post when i get home and have time :).
Thanks again all!
Thanks again all!
You have plumbed it correctly but in the stock set up there was a restrictor in the line from the intercooler pipe so without the restrictor there will be more air keeping the wastegate open (and so less boost).
If you can get the EBC working that should do the job.
If not grab the RB20 actuator on offer (shouldn't be too expensive) and again bypass the stock solenoid.
Or a cheap boost T would be better than nothing.
Oh, so there can be some problem with the restrictor?. Or did i get it all wrong? Haha
Not if you put all the stock lines back in. I was assuming that you didn't have the stock lines and just used some new hose which didn't have the restrictor.
Yeah i use new hoses. However, i tried to put a hose on the wastegate and blocked it just to see how much boost i could get.. and i still get around 0.3 - 0.4 bar.
Is that the right way to get max boost? or what should/could i try more?. I'm starting to wonder if it's the catalytic converter that blocks too much? it's taken from my brothers Volvo V70. But maybe that doesn't affect the boost at all?.
I recorded a video on my way home from work too show you how the car/boost acts. Was driving while holding camera but i'll guess the video works :)
Thanks again all :). Edited by Tungstenaxe
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
