  • 1 month later...
At the moment I'm ready to petrol bomb it...
Yes, I'm trying to get something done before trackday, but it isn't going much to plan. Hopeful that it will be done.
  • Like 1
Did you ever get the dump pipe crack sorted?
Yeah, the local guy down the road put a good 1/2 inch of weld on everything... Lol
It is all good I think, welded some re-enforcing into it as well.
  • Like 1
Where the dump pipe bolts to the gearbox, was all cracked and blowing. But got that sorted.
Annnnnd I may have broken a R200.... The 9 inch of the Nissan world :/
So - pre trackday update!
This car started life as a SR20 Auto, so it had a 3.9 ratio diff in it, while all other SR s13s came with a 4.11. Was originally a Open diff, and the previous owner put the Kaaz LSD in it. I was finding that the combination of 3.9 and the largish turbo was hampering me in a few areas of every track that I use. There were sections where it just felt so slow as you waited for it to come onto boost again. I noticed that I was just about one gear lower than all the skylines buddies that I track with. So I made up my mind, and decided to go to a 4.11. That's where the fun began.
So I got a R33 VLSD-A off Pezhead, that uses 4.11 and is a poo diff, so it was going to donate its crown and pinion. I dropped everything off at Award Gearbox and Diff, where Terry, Trish, and Mick were going to look after me. I soon got the call that the 3.9 Diff wasn't coming apart, even after a 20 ton, and then a 40 ton press. Something in the passenger side Stub was bunged up real good! So what they had to do to get it all apart was very time consuming, and had me running round like a mad man!
The Case (the big cast housing bit) was cut in the rear to remove/disassemble the hemisphere as much as possible. Once that was out, a very large drill had to be used to drill through the end of the Stub, to the point where the circlip sits, to free it.
Thankfully after a few phone calls through connections (its not what you know, its who you know ;) ) I had a S13 VLSD from JLM at Rydalmere to use the case from (the shafts and centre being different), and a matching Stub axle from Stuart Wilkins out at Mulgrave. Both life savers!!!
So now I christen it "FrankinDiff".
Its back in the car, and ready to test on Monday at SMSP. Most probably a wet day, but will be fun.
Box of left over Frankin parts
Can you imagine how hard this would be to drill through??
Ahh, after many phone calls, and much scavenging... its back together!
  • Like 1
I have access to a set of michelin wets, but can't really justify the cost of getting them mounted just for this day.
I'll run the street setup of Federal RSRs that have plenty of tread. Should be ok, not fantastic.
  • 3 weeks later...
Belated trackday wrap up.
I had fun :)
Car was good, I softened it out as much as possible and ran the federal RSRs in the wet conditions, never dried enough for slicks. The last session was a possibility, but no time to change them over as sessions were combined. Found the RSRs very pressure fussy. I dropped 2psi out and it turned into a dog, so I had to top them up again. they were happy round 36-37psi.
Car never got off gate pressure boost, which was well enough for the conditions. Struggled for grip in turn 5 which had some arse clapping moments, also round corp hill made for some interesting driving.Brakes were fine - really never got to temp.
Diff was great, so glad I had the Kaaz to make things predictable, and the ratio was an improvement, even in the bad conditions.
Fastest lap was the last lap of the day, the last session was great, having a tussle with Dave for 3rd/4th. Unfortunately he pipped me by something like 0.15 of a sec. So ended up 4th of a field of 37, happy with that.
I'm going to dump Track vids now...
Fastest Lap of the day-
Having a bit of a spin up the hill.
Taking BakeomonoRicer GT car master out for a passenger session. Small brown stain in passengers seat afterwards.
So, what's next?
I've got to get the car ready for the upcoming RTDC day on the North Circuit in October. Nothing much needs doing, but might treat it to an engine flush and some fresh oil. Hoping for dry weather to bolt the slicks back on and hunt some GTRs and Emos. :P
  • Like 1
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
