CA18 track car, not fast but potentially fast enough to move fluids around too much.
During a hot session where I'm going for it, the car recently filled the 1L catch can twice. I did not put the fluids back in as the dipstick seemed to indicate it had enough in it, but it should not have been overfull as I'd checked it before the track day. I am also finding that it would like to shoot out the dipstick if allowed - I have it wired to hold it shut.
After removing the oil I could hear ticking/rattling in the top end when going hard around corners implying no oil supply to the head/lifters.
I've checked and cleaned the balance tube when it was out last during head gasket replacement.
Both rockers are are plumbed to the can, the can has baffled and vented to atmo with a filter on it. The factory connection back to the intake pipe pre turbo is blocked.
I assume the PCV valve is working properly from the basic rattle test.
I thought perhaps it was just lots of blowby but it comp tests indicate it's healthy (but it is running 17-18psi). I am now thinking it's either not breathing as it should or during hard cornering/braking/accel the oil is loading up one one side and blocking the balance tube or some other form of return.
Thoughts?
If your dipstick is blowing out then you have excessive blow by. So your initial thought was correct, you can ignore the comp test as it wont tell you what's wrong in this situation. Your crankcase is pressurised. Simplest fix is to put a crankcase vent from your sump pan to your catch/breather can so the blow-by pressure can evacuate.
What you could do is put a hose on your dip stick tube and run that to your catch can. That would help and it is pretty easy to do. Much easier then pulling sump off and having a -12 fitting or hose tail welded on.
Edited by r33_racer
you have me a little confused...crank case ventilation happens at the top of the motor out the existing breathers....which if they are not evacuating the pressure fast enough could be causing too much crankcase pressure....i'm not sure what or why you would vent your sump....normally that is the return for the oil caught in the catch can.
You vent your sump because that is where the crank case pressure is - it blows up the oil drains making it harder for the oil to come down and it ends up blowing out the cam cover breathers.
And no ...do not T into the turbo return.
But yes try a tube from your dipstick tube to the catch can.
I know nothing about CA engines but feel OP would still benefit from reading the last 10 or 20 pages of the oil control thread (on about p3 or 4 of this forced induction section).
Pretty much as KiwiRS4T just explained. Virtually all piston engines are the same, work under the same principles and suffer from more or less the same issues when pushed on the track.
I wouldn't recommend teeing in the turbo oil drain also. The oil from the turbo will not actually drain as the joint will be constantly pressurised with venting blow-by. You will end up with oil leaking around the front/back turbo seals.
CA's, SR's and RB's I have seen them all suffer the same blow-by issues at the race track. They can all benefit from adequate crankcase ventilation.
is there a factory vent from the sump or do you need to drill and tap one? if you use a drain from your catch can it should be below the oil level in the sump to stop it blowing back up.
CA's have a "balance" tube, which goes from head to sump which certainly helps but is obviously not doing enough and the only other connection into the sump is the turbo return.
I'll do some more reading.
Not yet, haven't had any time.
Apparently I need to un-tee the two cam covers also.
They are currently both connected to the catch can, as is the PCV, can is baffled and vented to Atmo.
The connection to the intake is blocked.
This is all sorts of wrong but I'm not sure what is the best step to take to fix it. And what should be routed where.
Originally I had the intake side cam connected to the PCV as stock and the exhaust side connected to catch can and then vented atmo but it was still filling with oil.
No I have two half inch vents both above the oil level. One goes to the top of the catch can and one to the bottom. At WOT both act as vents and when you lift off any oil blown in can drain back.
  • Like 2
if you vent to atmo you need to make sure your catch can has venting size same as the inlet size e.g 2 x 5/8 fittings for inlet & outlet otherwise your catch can will pressurize. i also tried this system on my car but didn't really have any success with it...
http://forums.vwvortex.com/showthread.php?4387972-Bypassing-PCV-and-routing-to-exhaust-description-(DIY)-(long)
I hope this isn't a trade secret, but RIPS solution, on my car anyway, is as simple as this:
Two lines from valve cover breathers to top of vented catch can.
Two lines from catch can to sump, above oil level. One line is from the bottom of the can, and one is slightly higher (same as KiwiRS4T)
1.3mm restrictor (IIRC), note I have an RB26 and Tomei oil pump.
No head drains or any crap like that.
I don't think the oil stick tube will be big enough to act as a good breather, but I might be wrong.
Will report back if I have any issues with it, but I think that's unlikely!
OK here's what I've got and what I'm thinking.
How it looks now. Intake pipe is blocked, can is vented to atmo just near wiper motor. Excuse rag, it was put there during the track day.
Everything plumbed to can.
What I'm thinking.
Plumb intake side as per factory (green)
Plumb exhaust to can (green) and would include oil/air separator
Plumb Intake pipe back into can (red)
Plumb can to dump pipe (blue) using one of those one-way valve crankcase evacuation kits.
So it should have vac from the intake and the exhaust under all conditions.
The other option is do the same but plumb the intake side into the can as well and block the PCV.
Thoughts?
Edited by ActionDan
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
