It could be worth checking the contacts on your ECU plug. I had a similar issue with one injector not firing and it turned out to have a bad connection for that injector on the ECU plug.
I closed the female connection a little, plugged it back in and the problem hasn't resurfaced.
I agree, I have had this head f*ck a few times. It can be a pita to find, depending what pin it is. I swore the issue was dry joints in the ecu last time, but it was just the pin in the ecu plug had opened slightly.
I do know a guy that had the same issue also. He had to re-pin his ECU. Problem solved once done. Just figured it was just isolated deal for him since he swap a RB into a S chassis.
Ok update
Ive confirmed injectors are all working
I have continuity tested coil pack harness and injector harness.
Does seem to idle slightly better with cas unplugged but still rough
New spark plugs
Compression test came up with all cylinders fairly the same
  • 4 weeks later...
Ok i think ive narrowed it down after checking everything twice, i think the timing is out.
Ive the cam belt cover off a few times over the years and never a prob, could it be the cas is just decided to die. Or the wiring loom has finally broken?
I put a timing light on it and nothing lines up, used the white wire going to no1 spark plug.
Pfc is now saying 24deg and then bounces to 16 and everything in between when warm.
DVS found the issue to definitely timing, belt skipped three teeth, damn lucky to not have caused major damage, so it shoild all be sorted for track day currently getting timed and some stuff replaced... First time to a mech in 6yrs, and im glad i did
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
