can the team motto be
"Super Fun Happy Sliders"
which the closest japanese translation i can get is 極度な楽しみの幸せなスライダー
which when translated again = The extreme it is pleasant straw raincoat happy slider
  • Replies 120
me? I'm part of the mill park massif (including Roy, skylinegeoff, doxx and a few others)
.... its all good except the dress they make me wear :)
Team Trackday? Me wants in:wavey:
... me too, do i need vic rego, or can any hillbilly from a northen state play :hippy:
perhaps if u explained urself a little better as to what exactly it is that you were refering too we migh be able to be a little more helpful.
read the previous posts as there are a few questions which werent answered in regards to your question.
ie. this is a car club? were you refering to a drift team? a togue (sp?) team etc etc etc
Roy: yeah your probably right, i can't drive for sht so i doubt anything bad will happen, but just paranoid i guess incase i get lucky or unlucky...
Gojira: what do you mean oil supply up to track work?
Well the stock sump is nothing special especially if you are pulling some lateral G's with sticky tyres and roly poly stock suspension, I have heard that simply overfilling the oil by a litre is enough. But ideally a baffled sump and an oil cooler is some good protection.
I think the stock pump is fine on RB26 using std revs, i think it more to do with the fact that there is no oil around the pick up during sustained cornering, so the pump is always going to struggle so pump what isnt there. I think th epump is only an issue if you are usign higher then std revs, or the thing is shot to start with
i should rename this thread to FERNI's TRACK NEED- Needs HELP!
nawwww... jk
well im thinking of a drifting/racing/car cruise club sorta thing...
it was be tastey to see a mix breed of cars not only skylines.
if this can be done i have some people with silvia's and seven's lineing up and atm i just need some SAU peeepz in it!
thanks
There are some pretty well established non car specific clubs.
MCCR, Exclusive, TeamAZM, Fangartists etc...
One of those or a subgroup of them should suit your needs.
(If anyone is "ex" one of those clubs save your biatching for MSN)
But I will always be a Super Fun Happy Slider
...well im thinking of a drifting/racing/car cruise club sorta thing...
There isnt a name for it except a few folk going for a boring 3 hr drive, so to enjoy 6hrs of thrashing around at highly illegal speeds which must be reserved for these sorts of occasions...come one, come all.... :(
See Here
I dont really know any Vic guys (except for those poor few who havent been able to avoid me:Oops: ), so not knowing anyone isnt an excuse, actually its the perfect reason to come along, get to meet everybody and enjoy our cars :D
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
