Let ME start!!
Spotted a White R34 GTT last night around 12am at Thornleigh Maccas
Spotted a Black R33 GTT as well this morning at 9.30am Seaforth junction right after Spit Bridge...
Anthony's old yellow R34 and a white R34 Vspec at Thornleigh Maccas now
What meet was that? I was following a big group of supras, and a few old and ends down the commenara pky home last night.
Spotted you again, across the road :P
  • Like 1
Just saw nick ( goldzilla) in his stagea on fitzwilliam st toongabbie
You did, Brett? What were you in? I was on the way to give driving lessons to a friend who's had her license for years, but hasn't driven a manual since she had her learners.
Ahh okay, I was watching the Mazda3 on my left making sure he/she didn't try to do a dodgy from the left lane and try to pass me right where the camera was, then concentrating on kamakaze shoppers who regularly pull out of the IGA and that servo next door without looking properly.
Forgot to get plates. Spotted on Saturday ~
1: Around 5pm, Red R34 at Windsor Rd Kellyville. Gave you a thumbs up while you're stopped at red lights turning right :thumbsup: not sure if you saw me and my GF passing (Black R34 and White R34)
2: Around 10pm, Black R34 at Woodville Rd, Villawood. A little bit of fun too :yes: Also, you cut between me and my GF while shes following me. All good. Three of us in a line, nice. My GF thought you were me, she was about to follow you instead, not good. LOL. Not sure if you saw hers behind you.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
