Spotted a fake R34 GTR near my house. The body kit is disgusting.
The construction workers nearby were impressed when they saw two R34s parked next to each other :rofl2:
Edited by Wordsmith
There's a bloke that's moved into the building next to mine on the old princes highway at sutho that has a white R34. If you're on here I've seen your car a couple of times but usually when I'm running late for work so I haven't said g'day yet. Car looks nice though
Saw a beautiful white 370GT coupe parked on Barker St in Kensington near UNSW, SKY911. Also saw an awesome black R32 with a Nismo badge parked at Macquarie Fields shops CWN37T.
Edited by Wordsmith
Saw a white R33 coupe on Glenfield Rd about 10 minutes ago, I honked.
Wordsmith - that's my mates car, just sent him a screenshot of your post lol. He said cheers!
- Vik.
Are you sure it was his? The car was parked near the beach at about 1pm on Sunday.
  • Like 1
That's his on the right [emoji23]
Oh right I thought you were talking about the Bayside Blue GTR I saw at Coogee. Yeah I've seen the V35 around often in Glenfield.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
