Hi All,
Can someone please help me understand the difference between the following two items?
Blitz Intercooler SE Kit - Nissan Skyline ECR33/ER34 - Part No: 23100
Blitz Intercooler SE Kit - Nissan Skyline HCR32 - Part No: 23106
Core sizes are identical, is it the piping diameters?
What should they be for an R33?
Thanks!
I'd say the diameters are the same as well.
These kits are designed to line up to the stock piping in the engine bay, so I would guess the bends in the pipes are different.
I have one in my r33. I've never seen the intake piping in a 32 so can't tell you what the exact differences are.
my guess, and it is just a guess, is see how it is described as a "kit"? The core would be the same but the piping of this alleged "kit" would be a different pathway, although the piping diameter could, or may not be, or may be similar to, the same size. Possibly 64mm.
Re "What should they be for an R33?" , I would estimate, with no legal claim of specific knowledge to, or of prior events pertaining to, the piping contained in "Blitz Intercooler SE Kit - Nissan Skyline ECR33/ER34 - Part No: 23100", being as suitable for application to an R33. Or more specifically, an ECR33.
Hope that clarifies everything you needed to know, without searching the forums for the answer.
  • Like 1
Just to clarify as this is an obviously confusing issue. One is a kit to fit your car, the other is a kit that won't fit your car.
Different part numbers imply that they are actually different kits and the seller isn't just trying to look like they have heaps of different options to choose from. They do actually have different options to choose from.
However choosing the kit that won't fit your car would be a silly. But you have that option should you choose to take it.
As for the actual differences. If the core is the same then that would have to mean that the pipework is different.
Thanks everyone,
Yeah I'm buying a second hand unit with piping.
My car is an r33. The bloke in buying it from has an Rb25 installed in his r32, and he had this return flow installed.
Naturally I don't want the hassles piping not fitting etc hence the reason for my query.
It is far more likely to be the R32 one in an R32 than the R33 one in an R32. Now here's the rub. If it is the R33 kit in an R32, then it probably had to be modified to fit. In that case, and especially seeing as it IS in an R32, then you should buy an R32 to put the kit into, then you know it will fit.
The differences will be in the detail of where the holes are in the inner guard in front of the airbox. All the pipework will look the same between the two kits, it's just that there will be slight differences in length or bend locations that mean one won't fit in the other. You'll never work it out just by looking at photos of the one kit.
I concur with my learned colleagues above; regardless of an rb20 or rb25 being fitted to the R32, it would be more certain an R32 kit has been utilized in this instance. And not worth your buying.
However, one guy I may or may not have heard of, or even exist, once met another guy whose "R32 Skyline" turned out to be a VP Commo with a Mercury outboard engine fitted underneath the bonnet, so, buyer beware, that's all I'll say.
Unless you like projects, my advice to you my friend is avoid the pain, get the justjap cooling-pro intercooler kit, mine is still going choice bruzz for years now.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
