I don't think they exist - have never seen them. And almost nothing aftermarket like that is made for sedans, so I can pretty much guarantee you that you are out of luck.
You can however buy kits which put aftermarket angel eyes in standard lights - it is a fair job to do though I am told.
I would love the details also for the headlights also, i have been thinking about getting them imported from USA.
if there is a local Melbourne option that would be great.
Matt.
1. Remove headlights and take them apart
2. Fit RHD xenon projectors (with halo rings, what you're after)
3. Wire it all up
4. Assemble and re-fit
If you fit some good projectors in (google "TRS"), you'll usually get a better product than some el-cheapo crap off ebay.
The V36 should come with HID from factory, so what you'd ideall want is to just fit the halo rings, wire them up to parkers and put everything back together, nice and easy ;).
Today I pickup my beast and I will let you know the outcome of the lights as I will also be seeing my mechanic about these halo ring? I will add a photo of my car for everyone to see.
Thanks for all the feed back, unreal forum.
You would struggle to find RHD headlights from a USA supplier..
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
