Evo 6 Turbo On A Evo 7 ? 10.5T Vs 9.8T Vs 9.0T?
By StreetWeapon · Posted
This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
