HT have a few home made splitters in the build section
More info mate who is/what is "HT"???. I need help. 2 Build sections Motorsport and Projects, Overhauls and Build-ups.
Cheers
Neil.
Would it make the car unbalanced at all having a front splitter with a factory rear wing?
Always easier to get rear end aero 'grip' than front aero 'grip'. Wings are easy by comparison to splitters.
Neil
Get under the Radical and take some photos ;)
No need Zeb,,, I can tell you whats going on under the Radical and all other Sports/Prototypes.
The Radical has a flat floor which extends all the way back to the rear of the cabin and then it has a massive diffuser much like a DTM car.
The other type is a tunnel system which is basically a diffuser that starts at around the front axles and goes all the way back to the rear of the car. Not practical for sedans as the tunnels go either side of the driver so it's only good for centre seated sports cars.
I've been looking at making a splitter out of this stuff
http://www.alusign.com.au/
has anybody ever used it?
Cheers
Neil.
Hard tuned
http://hardtuned.net/forums/index.php?showforum=389
But there is a f**kload of pictures/how-to's in google if you type 'home made splitters' some from people who actually race (why i mentioned HT)
You guys would know a lot more than myself. But i always thought splitters would only be good on fast tracks with high speed turns and having a low enough car, so it doesn't lift the front up?
And going on from your post Neil, would a splitter that went back further than the front bumper be better? or I'm guessing it would be a case of trial and error, and what type of bumper and other mods are used?
Edited by Stagea97
I made mine out of marine ply (15mm), like Russ's its flat and goes back to the steering rack.
My understanding (not a professional) is the splitter works best when there is the greatest pressure difference under the car. So you need to block off as much of the front of the car as you can so air doesn't go under the car from through the front bar.
I also added a NACA duct on either side under the splitter for oil and intake cooling.
It will only work if it's solidly mounted to the car, if you can't stand on it (80-100kg) it's not going to me doing much.
What we all really need is a fully covered undercar,,,nice and flat leading into a big rear diffuser. That really can't be done,,,the exhaust being our major stumbling block. I just stuck my head under my GTS-T and the front splitter has to stop just before the dump pipe. You could make cutaways around it but what a pain in the arse that would be. It's also very impractical,,,you would lose all your jacking points and servicing/repairs/cleaning kitty litter out after an off at race meeting would be a bloody pain.
So lets forget about the front for a sec and see what else we can do,,,my thinking is one of our major problems is air getting stuffed around by everything under there and then it comes to a screaming halt at the rear bar. Now maybe we should look at making something that lets the air travel out the back more smoothly,,,yes a diffuser would be great but in the interim just smoothing out the air flow back there might help.
Cheers from the aero genius,,,NOT
Neil.
Neil.
Marine ply + Gate = Fire :woot:
Neil.
Yeah that's why not many people do it. Very fiddly making something so custom and vulnerable. Eliminating as much turbulence as possible is the answer...
as above.
I have used both alupanel and normal ply. the alupanel is about $120-150 a sheet, ply $50 a sheet. Ply takes a lot more abuse where as the alupanel is kind of like a knife if you go off track (which i do a lot :) ) and can dig into the ground and rip off. interestingly thats when i learned how much it was helping, in all but 2 or 3 corners a wakie after it came off my car started understeering a heap more, like a normal 31...
my splitter comes out about 80mm from the bar lip and goes back to the crossmember. it also helped a lot with cooling.
ive learnt alot from the aero section in here > http://www.timeattackforums.com/forums/
you still down the road andrew? your more than welcome to come have a popeep
My undertray also goes past the crossmember, as per James. It was conceived to assist solve cooling issues, and to date seems to have hit the mark.
The front end grip improvement is an added bonus, can only think that a decent splitter takes it up a notch or 3 depending on detail.
Composite board prices seem pretty steep down South, more like $80 in Qld.
Thought I might chime in on the discussion here. I've done a lot of fibreglass and carbon DIY so have some thoughts to add.
On the subject of strength, we need to remember that the down force created by the splitter is spread across the entire exposed area. So to say you need to be able to stand on it is a case of over-engineering. Total down force is spread across area to get Force Per Area e.g. PSI or kg/cm2.
The lip I built for my car is only 3-4 layers of fibreglass and one layer of carbon. This was enough to structurally withstand a traffic cone hit at around 40kph. It only cracked and fractured it a bit. Easily repairable.
So I don't think you need to stand on something to test it. The PSI area of the shoe contact area well exceeds any down force you can get from air movement.
What you do need to consider is your mounting point structural integrity (e.g. material & strength).
Short explanation:
When choosing material choose for lightness and strength. If the material isn't strong enough at a pin-point load, reinforce it with other materials such as washers or metal plates layered into the construction.
Long Explanation/theoretical maths (All approximate guesses, so please don't take the maths and measurements too seriously):
Say you are bolting it to the car across 10 mounting screws. For the sake of ease, let's just assume that load is evenly distributed across those points (it won't be and must be considered). Let's also assume that the 10mm bolts are used so there is no real possibility of fastener failure either.
So say 200 kg of down force is spread across 10 points. Each point taking a 20kg load.
Now, a fastener with a 1 cm washer might have an area of 0.8 square centimeters. But you also have to remove the area of the hole for the screw from the material (m5 hole @ 0.25 sq/cm area). This leaves you with about 0.55 sq/cm of area in the material. So you are expecting the splitter material to withstand 36kg/cm2 without pulling through the material.
If you increase the washer size to 2 cm the area increased 3.14 sq/cm (ala PI*R2). Now the area without the M5 size hole is 2.9 sq/cm and thus load over that area decreases to 6.9 kg/cm2. So doubling the size of the washer, re-distributed the workload area over 5 times in this instance.
Load spread across the entire splitter will be the 200kg over the area of the splitter. If the splitter extends 10cm in front and 1.5m wide then the total surface area is about 1500 sq/cm. So the pressure load per sq/cm would be about 0.13kg/cm2.
  • Like 2
Here is a few pictures of the front bar off the race car. Its not a home made splitter(carbon fibre bar made by a local bloke), but it might help with how to mount the bar and splitter and make it quick release. 4 mounting spigots with some simple latches on the top two to hold it in. The bottom two just slide into the receiver tubes (welded to the bottom of the radius rod mounts) and bottom out.
Hopefully that might help with someone having a go at making/fitting something up.
  • Like 3
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
