Hey I've been having random starting issues and after it finally showed a diagnosis code I removed the cas - and I found the the exhaust cam bolts have rubbed against the cas! Am I missing a gasket or something to give it more room?
I would have hoped the mechanic would have noticed when they were adjusted!
https://www.sau.com.au/forums/topic/446065-adjustable-cam-destroyed-cas-wtf/
Well when I got it back from the tuner it had new bolts on the cas - so I'm thinking they replaced the original and didn't put washers back on!
I think I will be having words with them....
  • Like 1
Wow.
And looking at it it appears to be set to zero. Bit hard to see in the photo though.
I think it has a small adjustment.
I've put it all together and it still won't start - the injectors ticked when the cas was spun, and there's spark in the plugs - so fuel problem?? Or would the replacement cas put the timing too far out to start it????
Piggaz is on the money. No washers inside that rubber gasket causes the cas to get too close to the cam gear. It doesn't look like there is any of the washers inside that gasket in the pics.
Edited by Chris32R
R32-25t - I think that mark is where a washer used to be as the gasket is pretty hammered!
double check that the input shaft for the cas hasn't snapped off
Yeah the input shaft locator is broken off in the cas - so I'm trying to line up the new cas into the shaft, but it's bloody hard!
AF53B8B7-3F5C-424D-9AB8-F0DFBBF75FC8.png that's a washer, you can see the outline of it clearly
Ah I can see what you mean now I'm at the car - there is a small washer inbuilt into the gasket on the cam cover - if this is all that's needed I'm confused how the cas was touching the cam bolts....
can happen if the wrong washers are in there (not thick enough) but hard to say just from the pic. They look right, but you might be best off doing some measurements I think. Measure the thickness of the washers, etc. If you can source another CAS (cheap second hand one might be best) and put it in the car then turn it over by hand slowly and listen to see if it rubs it might tell you a bit more. I'd order a new seal and washers, not that expensive.Then see if it still hits
I've now replaced the cas - as it was scored on the inside.
I have got the car briefly running with it all together - and I think it is clearing fine as no marks are on the new cas so the gasket with washes included must be fine.
On reflection, ages ago I had the car running without the cam cover for a short drive, and didn't hear / see it rubbing, but I guess it must have been - a lot of damage with only 10mins of running!
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
