<p>Hi,</p>
<p>My 1994 R32 GT-R has two possibly related problems. After driving for about five minutes the power steering basically shuts down and the steering is heavy as if it has no assistance, at about the same time the HICAS light comes on.</p>
<p> </p>
<p> </p>
<p>The power steering fluid level is normal as is the reservoir in the boot. My mechanic says the power steering pump is not showing any obvious signs of problems and the car is genuine low mileage and generally mechanically excellent.</p>
<p> </p>
<p>Any suggestions, before I take this to Nissan?</p>
<p> </p>
<p>Note that the steering returns to normal when you switch the car off and start again though I have not worked out how long it takes to "reset".</p>
https://www.sau.com.au/forums/topic/446077-heavy-steering-and-hicas-warning/
Similiar problem with my 33, it could be the g-sensor under the center console,or the capacitors in the hicas computer, because of there age they start leaking fluid.i replaced the g-sensor with a digital one from nengun about $500 and had the local tv repair man replace the capacitors in the computer for about $70.
Had the exact issue with my 33. Hicas computer faulty. Picked up a second hand one for $50. I was able to swap it with a friends 33 just to be certain before I replaced it.
Edited by Aazzy
Hi. Car had a aftermarket steering wheel, but I swapped it for a stock one. The problem remained.
Just tried several times to invoke HICAS diagnostics mode but it just won't play ball. I guess this might indicate a faulty HICAS computer as mentioned in above posts?
Maybe. Nut that's why I suggested if you fail at getting it into diag mode on your own that you use a proper scan tool. The method for getting it into diag mode relies on various inputs still working (steering angle sensor, brake signal, vss, etc). If one of those is faulty then you can't get into diag mode to find out that it is faulty.
By "proper scan tool" you mean something that any Nissan workshop would have or are these some more specialised? Anyone in Adelaide want to recommend the best mechanic/workshop or Nissan service centre to work on this problem? I've had other work done at Main North Nissan, but they don't seem that good e.g. didn't know how to adjust the air/fuel mixture on a Datsun 280ZX!
The reservior in the boot is for ATTESA not HICAS. Also the G sensor isn't used by HICAS AFAIK (R32 remember).
Most likely the computer under the boot. Unplug the smaller plug (there are two) and see how you go. The computer is located on the driver's side, under the parcel shelf.
The manual steps to invoke the diag mode is a pain, it took me a few tries to get it working.
Brenton @ Foursnmore in Pooraka has a scan tool that I have put onto my car and seen every computer come up for diagnostics (granted, that's only the ECU and the HICAS these days...not having TCU or ABS modules in the car reduces the possible number you can see!). And also on things like auto Legnums I've seen the ECU, TCU, ABS, etc all come up and drop their pants for inspection. So much easier than trying to make diagnostics happen manually.
  • 1 month later...
An update on this. Main North Nissan sent the car to Clisby who took the HICAS ECU apart and cleaned it up a bit, but still faulty. I'd like to track down another ECU but the ones on ebay have quite different part numbers. My has part number 28505 12U00 and serial 4623. I can't find anything like this. Would a ECU with number 28505 04U00 work? Does anyone know how to interpret these part numbers? Was my 1994 unique in having this HICAS ECU part number?
  • 2 years later...
Update on this for anyone interested. I've owned the car a few years now and still no resolution to this issue. Within a few minutes of switching the car on I get zero power steering, followed a few minutes later by the HICAS light coming on. I know the HICAS is all working (passes all diagnostics) so this continues to be a mystery of the Universe, right up there with Dark Energy and Dark Matter. I'm calling this Dark Power Steering Failure.
If you have eliminated the hicas ecu as the issue, then you can try removing the cluster and have a good look at that, you will need to take it right apart and examine where the taco mechanism seats into the cluster. What you are looking for, is a small electrical plug that takes the rpm signal from taco and joins it to the rest of the clusters wiring. Carefully clean the contacts and make sure the plug is seated correctly when you reassemble. While you have the cluster out, make sure you clean (very carefully), all those annoying cooper trace connecting wires at the back of the cluster, and be very careful with the end of the taco cable too.
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
    • To drain the Intake Heat Exchanger, there is a crappy drain plug in front of the driver's side front tyre: You should use the largest headed phillips screwdriver you had, and in my case I needed vice grips on the hose above as the plug was tight (tighter than it needed to be, since it has an o-ring seal).  After you have a tray down and open the drain, open the intake heat exchanger reservoir cap (drivers side one) and you should get a couple of litres of coolant To get to the radiator, you need to remove the plastic engine undertray. It is held on with a series of 10mm headed bolts and some clips. For the radiator, there is another type of crappy drain (kind of like a plastic banjo bolt) and you should attach a length of hose to direct the stream of coolant per this pic (otherwise the coolant hits the rad support and goes everywhere). The drain is on the rear of the radiator on the driver's side and a bit hard to find. Put a big tray or bucket down (5l won't be enough) and slowly unscrew the fitting by hand. You only want to remove it far enough for coolant to flow, it you unscrew it right out the whole fitting and direction pipe will come off and you will get a coolant bath (yum!). Undo the radiator reservoir cap and it should empty about 8l
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You also need to drain the intake heat exchanger to remove the radiator so you will need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. 2 other tools that really help dealing with coolant lines and spring clamps are Bent Needle Nose pliers Hose pliers Between them they will reduce the frustration (and injury) potential by about 1000% Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
