HI We are in the last stages of getting our R32 lemon on the road
After 18 months and 2 mechanics and almost 10 grand later !!
The mechanic is struggling to get it tuned
It has a bigger turbo and a standard ECU
is this the problem ?
do I need to get an upgraded ECU?
This car has almost sent me broke
but its so close now we cant give up
Any advice would be appreciated
Our daughter got majorly ripped off when she bought the car
and we thought we would buy it from her to get her out of trouble
so we have no idea about skylines really.post-117189-0-04216200-1406538866_thumb.jpg
https://www.sau.com.au/forums/topic/446139-r32-ecu-help-please/
Hi
It has stock injectors
And I dont know what turbo but its twice the size as a stock one
Its the one that came with it
The mechanic isnt trying to tune the ECU
sorry I ment just running smooth
It went better with a new fuel pump
but he said its not getting enough octane ?
Does that mean I need a new ECU
or upgrade?
What does a daughter board do ?
This is a second hand ECU I have for It
the Auto electrician said the old one was burnt out
Thanks again :)
Check out the link provided to you by Geoff. A Nistune chip inside your current ecu will make that ecu tunable. Or if you want to spend another $2K you can get a Link or Haltech or other aftermarket ecu but the Nistune will work fine for much less dollars. Once you have a tunable ecu you can stick it on a dyno and it will show if you need bigger injectors, afm and better boost control...but the tuner should be able to tune within the capabilities of what you have now.
And where do you live? Find some local RB enthusiasts to come and have a look at your car and make (hopefully) helpfull suggestions!
You have a decision to make.
Both involve going to a different workshop that know what they are doing..
1 Return car to stock and drive it.
2 Spend a fair bit more money on a tuneable ecu[nistune], fuel pump, potentially injectors afm and clutch etc then dyno tuning and have a quicker car. Maybe. Depending on what turbo that is it might be a pig.
Also your breather and pcv setup is totally wrong. Which will cause you issues. Who did that? If it was the mechanic walk away now.
(The black hose on top of the cam covers going to the blue t piece then onto the inlet manifold)
Hi Wow
You guys are really helpful
Were not really after a faster car
just one that goes
Thanks Ben Ill check if its still like that on Monday
and I think the stock option is best for us
Could you tell me what else you see thats not stock?
We have no idea!
Most work was done at Barnes High Performance
Sunshine coast
He had it for 8 months
then gave up and sent it back
to our mechanic with an auto electrician he suggested to re wire the loom
Ill get some up to date photos on monday
maybe its different now ?
Thanks again
Liss
We are on the Sunny coast QLD
Going to stock is the most sensible, cheap and easiest option.
You already know the turbo is not stock.
Other non stock visible items are the turbo manifold (what the turbo bolts onto). The cheap ones tend to crack. They position the turbo very differently. This causes problems as you can't run the standard air box typically or the standard intake pipework. Cops will pick up on it quickly.
If you keep an eye on the forums, exhaust manifolds can be had for around 50.
The blue 90 degree bend and intercooler pipework also isn't standard. Not really a problem though depending on how good it is.
Happy to try and help if you need more info.
So today we decided just to bring her home
where we can try out some of your suggestions
Weve downloaded the workshop manual so we can
understand what we are doing somewhat
Heres the current state of the under bonnet
I took a video but its too big to go on and now she needs
more fuel so Ill do a shorter video of her running rough
What fuel should we be putting in 95 or 98 ?
I was mistaken when I said it had stock injectors
they are bigger too ! cant remember what size though
Thanks again
The BOV is blocked up
I was told it was ok to be blocked
just wont get the noise ?
Is that right or will it be causing other problems ?
Would appreciate it Ben
Thanks
Let me know if you need to see specific parts of engine
I didnt really know what to take pics of :)
Having the bov blocked is better than having it venting to atmosphere, but still not as good as having it plumbed back correctly. It can cause issues of running very rich when changing gears, and will actually be louder with it blocked (and make you sound like a wanker, trust me)
The bolt blocking the blue hose on the front of the engine is poor, you can get little caps to do it properly.
The breather system really needs to be sorted, but to do that properly means a new inlet pipe.
So its either keep the turbo on that manifold and get a new inlet made, and potentially have the manifold cracking, or get a stock manifold and pipework, fixing bov and breather and cracking manifold in one go.
You don't need to buy a clamp like what's on there, a normal hose clamp is perfectly fine.
Can you take a photo of the turbo from the back, and try to get a couple of the manifold.
And bigger injectors on a stock ecu is never going to work properly, unless you spend the money on a nistune.
Edited by Ben C34
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
