R33's have a double latched setup from factory... you could pull the bonnet release cable at 200kph and it wouldn't fly open...
Of course you're more than welcome to make your own additional restraint with a carrabeana and a loop of wire to secure it further.
Edit: I would be running the additional if I had an aftermarket bonnet, carbon fibre, bracing removed, or something like that which could allow the bonnet to flex more than normal
Well bugger me... I come back after a day and have to cater for a few more!
BBQ for Members:
Tony +1
John P
Simon
Anna & Luke
Paul S
Michael +1
Jamie
Owen
Dave
Allan
Matt L
Snowy
Gorjan
Chris T
Richo
Pete
Jamie L
Jamie G +1
Lebo Luke
Mark
Matt B
dan.1337
Total - 26 people
Is there ANYONE else??? Given it's a pretty hefty increase in numbers already
  • Like 1
Hi guys, I have been reading the supp regs and the cams manual and just want some help with one thing.
Do I need to run an extra bonnet restraint cable or is the factory latch ok??
Cheers
Luke
You should be ok, a long as it has the two methods of fastening.
They can be a bit picky on after market bonnets though.
Not required. Just eat and be merry.
Squires Loft Nunawading is supplying the food at cost and cooking/extras for free. In return SAU-Vic picks up the raw food bill on members behalf as it's a Members Only BBQ - one of the many member perks!
Great too see so many faces around.
Yes I did try and remove the speed limiter from the Evo. Only to have the battery go flat...
The speed limiter is gone now and car working fine. (Frkn Evo's)
Thanks too Squires for the food, amazing as always.
Not sure what others thoughts were, but this day ran better than previous days of late.
Bearing in mind a wrx dumped oil and some chev driver painted the armco.
There is a discussion in the champ thread about the 30th of August at Winton. Get in there and have ur say.
Obviously gutted for members with day ending issues
But yeah, excellent day, started to run so quickly at the end that my car couldn't take it anymore and I believe quite a few were setting PBs etc, big crowd, excellent food - missus complaining I'm getting fed to well, what diet :-)
Was a much better day, even if i didn't make full use of it. Some minor attention this week and I'll be sorted. :)
100 cars, awesome. 120+ cars, shithouse.
Day was run perfectly compared to the other 4 rounds so far this year, which the oversubscribed side was pretty much the cause.
Let's hope it continues!
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
