R33's have a double latched setup from factory... you could pull the bonnet release cable at 200kph and it wouldn't fly open...
Of course you're more than welcome to make your own additional restraint with a carrabeana and a loop of wire to secure it further.
Edit: I would be running the additional if I had an aftermarket bonnet, carbon fibre, bracing removed, or something like that which could allow the bonnet to flex more than normal
Well bugger me... I come back after a day and have to cater for a few more!
BBQ for Members:
Tony +1
John P
Simon
Anna & Luke
Paul S
Michael +1
Jamie
Owen
Dave
Allan
Matt L
Snowy
Gorjan
Chris T
Richo
Pete
Jamie L
Jamie G +1
Lebo Luke
Mark
Matt B
dan.1337
Total - 26 people
Is there ANYONE else??? Given it's a pretty hefty increase in numbers already
  • Like 1
Hi guys, I have been reading the supp regs and the cams manual and just want some help with one thing.
Do I need to run an extra bonnet restraint cable or is the factory latch ok??
Cheers
Luke
You should be ok, a long as it has the two methods of fastening.
They can be a bit picky on after market bonnets though.
Not required. Just eat and be merry.
Squires Loft Nunawading is supplying the food at cost and cooking/extras for free. In return SAU-Vic picks up the raw food bill on members behalf as it's a Members Only BBQ - one of the many member perks!
Great too see so many faces around.
Yes I did try and remove the speed limiter from the Evo. Only to have the battery go flat...
The speed limiter is gone now and car working fine. (Frkn Evo's)
Thanks too Squires for the food, amazing as always.
Not sure what others thoughts were, but this day ran better than previous days of late.
Bearing in mind a wrx dumped oil and some chev driver painted the armco.
There is a discussion in the champ thread about the 30th of August at Winton. Get in there and have ur say.
Obviously gutted for members with day ending issues
But yeah, excellent day, started to run so quickly at the end that my car couldn't take it anymore and I believe quite a few were setting PBs etc, big crowd, excellent food - missus complaining I'm getting fed to well, what diet :-)
Was a much better day, even if i didn't make full use of it. Some minor attention this week and I'll be sorted. :)
100 cars, awesome. 120+ cars, shithouse.
Day was run perfectly compared to the other 4 rounds so far this year, which the oversubscribed side was pretty much the cause.
Let's hope it continues!
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
    • To re-cap, I bought: https://www.alibaba.com/product-detail/Lsailt-8G-Infiniti-Q50-Q60-2014_1601171829627.html?spm=a2756.trade-list-buyer.0.0.2cd476e9FTIlKE As you can see, if I bought 20 it was $653, but I bought 1 so it was $1,170. I was very tempted to buy 2 and resell 1 at 25% cheaper. @MBS206, I am not sure if they do a Kluger one, here is their list but it might be there under a global model name: http://www.lsailt.com/product/android-interface?page=1 Keep in mind these full android replacements have basically all the bits a phone does (cpu, ram, storage, wifi, bluetooth, usb interfaces) other than a screen (it uses a host), thus the $800+ cost. Android Auto screen mirroring is MUCH cheaper as it's just a cut down shell, input mirroring and output mirroring BTW I also need that "screen off" feature, it is much harder to see wildlife even if a dash is reasonably dark. Both the Fuga and V37 have display off buttons for night use, they just come back on for a second or 3 if you interact with it, eg skip a song.
    • I use FCC car launcher. It has an option for different backgrounds, so instead of turning the screen off you can swipe 'up' to a black screen with no background/icons. (mine has the time on it only). It's kinda nice. Also lets you use gestures to say swipe to go to next song, etc.
