Hey guys
I'm soon to get installed the following mods
gtss turbos,
tomei dumps,
Hks front pipe,
kakimoto 3.5" exhaust and
either 3.5" straight pipe or 100cell cat
I have a viper ecu, elec boost controller and handling mods
I'm hoping fir 320-330 awkw on this, fir fuel set up I'm getting sard 700cc and planning on a Walbro 255l pump
Is this all I'll need fuel wise to support my power goal or do I need to get a fuel pressure regulator and fuel rail too??
Any other thoughts on what I'll need to hit my goal?
https://www.sau.com.au/forums/topic/447046-fuel-requirements-rb26/
For a few bucks more you may as well get the Walbro 465L pump which is ethanol friendly in case you want more than 500hp and decide to get E85 some time. Directly wire it and you won't need to revisit your fuel pump for a long time.
  • Like 1
I was contemplating a 460 unit, I just thought it would be excessive. I'm thinking about e85 next year but thought the 460 would sound like a lawn mower starting up.
For $185 they are hard to beat, and the new turbine design is nearly silent. ;)
Bro. Pretty sure they are doing a he'll of a job while still pumping power through the motor that is just as old but probably will hold 300kw longer than the life expectancy of a ford
My XR6 Turbo had 325rwkw and 400,000 kms on the clock...
Well having just lodged my tax return im getting a lazy few thousand back... soooooo im thinking about getting poncams while i get everything else done.. given ive got the turbos fuel and exhaust im thinking it should be worth it..
now i've heard mixed thoughts about whether to go R, A or B, im thinking i might aswell go B cause the GT SS will be responsive as hell, i dont mind an angry lumpy idle and also if im going E85 down the track will help the top end figure?
thoughts?1
If you're gonna go cams. Stock, type R or mines shore pro 2. Tomei type b's, too much duration for lift given.
Pm XKALABA. He has done a back to back between the 260 and 250 poncam. Sometimes, bigger isn't better.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
