Hi
I have recently bought A 370GT P Coupe Auto.
Driving up Henri Robert's Drive Tambourine Mountain in the rain ,steep and windy, the slip light is on most of the time regardless of how smooth or slowly I drive. Doesn't inspire confidence
It is fitted with YOKOHAMA Earth 1 tyres in as new condition.
Can anyone recommend a good wet weather tyre that they have actually used.
I have asked this before but was unable to get a reply.
What does the 370GT P have in the way of traction control and what does the SNOW switch do
I bought a work shop manual ,DVD, and can't find any reference to TC or the SNOW facility
Cheers
Steven
Are front and rear tyres the same rolling diameter?
That will cause issues with traction control of they aren't.
I already told you about snow mode, it takes off in second gear. And it has traction control. What more do you want to know?
As Ben says, if you've got tyres that mis-matched in terms of rolling diameter it will cause issues.
I had 225/45/18 and 265/35/18 combo and at the slightest drop of the clutch the TCS would kick in - actually it was a little dangerous as if you had to merge into traffic it would cut the power!
When the fronts needed new tyres I went to a 225/40/18 and its much happier now, you really have to drive quite hard to get the TCS working, its made it all much happier
If the tyres are the same all round (or the very similar rolling diameter) and you have issues then I'd be looking at the sensors
With the utmost respect Ben I am not sure if that is correct, if it were a manual car how would it take of in 2nd gear and with the Snow switch on it will easily chirp the tyres, in second Gear!
Regards
Steven
ps
I am not looking for an argument simple trying to understand what is happening
Regards
Steven
ps
What? It's not a manual. It's an auto.
I would think if it was a manual, it wouldn't have a 'snow' button..
I would expect they would all have at least TC.. if also it has VDC, it will have a VDC off button somewhere.
Try these...
See if they help..
2008-infiniti-g37- VDC.pdf 2008-infiniti-g37-om snow.pdf
When I first got my V36, I also found it slippery, but that was the tyre release agent. Once that was gone, all good. I now only get the slip light when I deserve it.. :whistling:
The extremely easy way to see what happens when you engage Snow Mode is to do it. Then you wil understand in 30 seconds what it does. And of course manuals don't have a 'transmission mode' button lol.
But yes I completely agree with the guys above - I am willing to bet you have mismatched tyres either front to back or side to side.
  • Like 1
No problems.
I have Nitto Motivo 245/45/18 both front and rear, replacing the 225/50/18 front and 245/45/18 rear Chinese compliance tyres. Cannot remember the brand...
225/50/18 does not fit properly on an 8.5 inch rim, as per rear of V36. Generally 8.0 is the widest wheel that would take that size comforably, unless you are going for a streached look... either way that would partially explain a wobbly rear end...
In addition the Yokaham Earth range of tyres are hippy hippy baloney greeny tyres that are optimised for fuel consumption, not grip. They also are not available bigger than 16" for AUS market,
I think what you have are the BluEarthA which is a JDM tyre, still not approved for 8.5" wheel..
I would change the tyres as a good starting point for sorting out these issues. Get with a quality set of 245/45/18 front and rear... A lot less coin and hassle than finding the wierdo 225/50/18 fronts..
Also consider that if your rear tyres (that are fyi significantly too narrow for even stock power levels) are actually JDM and not Australian DOT approved, if you have an accident, your insurance will NOT cover you whatsoever, as any JDM/non-DOT-approved tyres are illegal for use on Australian roads. Just something to note.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
