Hey people, just wondering if anyone has used this product: SCG-1: Solenoid Boost Controller w/Wideband Gauge Kit (ALL-IN-ONE) - P/N: 3882
Link:
http://www.innovatemotorsports.com/xcart/product.php?productid=16351&cat=276&page=1
It says:
The Innovate Motorsports SCG-1 is a revolutionary approach to boost control that integrates an advanced standalone boost controller with Innovate’s industry leading DirectDigital™ wideband air fuel ratio technology. When we decided to build a boost controller, we knew we had to offer more capabilities than other products available today, while still maintaining the user friendly functionality demanded by our customers. Instead of repackaging the same boost control technology that has been used for decades, we choose to pair our advanced O² sensor control technology with our all-new, proprietary solenoid control that provides superior boost control accuracy, response and safety. We also added a user programmable shift light and housed the entire package in a compact gauge body for ease of installation and use.
Looks like a decent product.
Wasn't there another thread about this only a few days ago?
Either way, it seems like a product for those with limited space, not a killer product in its own right. The marketting waffle about smurshing the boost control in with the wideband has got nothing to do with improving boost control. They are completely separate functions jammed into one housing. I'm sure the solenoid control is no different to any other EBC out there.
Digital gauges can eat a dick too. Analogue needles are much easier to see. Plus, if this thing has a shift light, plus alarm lights for overboost and possibly AFR all in the same location, that's not particularly ergonomic either.
Apart from all that, I like it.
  • Like 1
Convenient. But I could implement it with pretty much any decent wideband controller and the Profec I have now. Profec has remote switching input to toggle low boost setting.
Yeah true, But I havent got a ebc or wideband so I suppose its killing 2 birds with one stone, plus I could connect the 5V output to the ecu to tell it to apply the limitter and add fuel if a lean situation occurred. Just thinking out aloud. For about $450 I think its good value. Be nice if it had an analogue gauge though.
Any negatives you guys can see?
Edited by XGTRX
On that basis it's a good looking tool.
I like the Plex one more, but even I have to admit that I wouldn't want or need 80% of what it can do.
And at $1300 for the Plex its hardly good value for the money, I looked at it but my ECU can do most if not all of what the Plex can do I just have to get the touch sceen and sensors then set it up
I like the progressive shift lights better as they give you warning to get ready to shift instead of seeing the light and going a few hunderd RPM past your shift point, when you have a car that will snap a speedo in a second flat its good to see it coming, lol
Agreed, progressive or dual stage are better. I have mine coming in green at 500rpm under and then a red at the shift point which is 500 rpm under the limiter.
Here is a video on the abovementioned unit.
Innovate Motorsports SCG-1 Electronic Boost Contr…:
Well I have ordered the unit. I thought it was good value for money for what it does, solenoid is on par with other reliable brands. So I will do a little write up of the install for anyone who is interested and let you know how it goes.
  • Like 1
Wouldn't it make more sense to have a probe for each cylinder, as if one cylinders leaning out, the average 02 that the wideband gives may not show any issues occurring, or maybe that's going to far?
If you have a vacuum leak or a aftermarket plenum, you could have a cylinder that is overly rich or lean. Don't some tuners add extra fuel for the rear hotter cylinders ?
I agree, if you were on petrol anyway. Ethanol, who cares if it leans out a little. :P
Widebands don't read accurately in a pressurised environment as I found out the hard way, so don't ever put them in the manifold. You would need temp probes in each runner , then a wideband in the front pipe. (not that anyone could afford 6 wideband sensors, even two would be overkill.)
Don't you have to run these Bosch sensors in the collector just before the cat or they are inaccurate. I think they need to be at least 20cm from the turbo. I will probably weld the bung in the collector, could have one in each front pipe as XKLABA suggested. Might see if I can use the shift light as a lean warning light too. See how I go.
Edited by XGTRX
Depends on the quality of the O2 sensor, I am looking at two HTK L2H2s to put in the factory locations ( mostly because my ECU comes calibrated for them )
Cheaper O2 sensors would shit themselves pretty quick in that location, but the closer you can get to the turbo the more accurate/responsive the O2 signal is
I hardly think response time would change being closer, or accuracy for that matter.
If that was the case the dyno o2 sensor in the tailpipe would be virtually unusable.
Edited by Ben C34
I wonder why then nissan decided to get top quality sensor and put one straight out of each turbo instead of just one infront of the cat
My tuner has told me closer to the turbo the better and so has the people at Syvecs where I got the ECU from
Because it's a different type of sensor.....
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
