Hi All
After some 'hektic' pinging problems, and 'hektic' blow by my engine finally blew about a week ago.
I dont know how many cylinders are gone but it doesnt go very fast anymore :) haha!
So I ordered in some parts and they all arrived today!!!!
- Neo RB25DET
- Hi-Flowed VL Turbo (I think they are T04's? Correct me if I'm wrong)
- EMS Computer (Will be tuned by V Rigoli)
- Powerdigger Electronic Boost Controller
Already have mods:
- Hybrid 600 x 300 x 76 FMIC
- 3" Exhaust
- Pod Filter
Hoping for somewhere around 200 - 220kw @ the wheels at @ 14psi
https://www.sau.com.au/forums/topic/44775-neo-powered-r33/
good luck with the build....sounds like there could have been cheaper options tho? why the neo engine for example, they could just rebuild what you already had :confused: Same with EMS, why not just use a PowerFC?
https://www.sau.com.au/forums/topic/44775-neo-powered-r33/#findComment-914913
I chose the EMS and 34 Engine because I have the means too.
My uncle is owner of Stevens Prestige at Lansvale he had a Neo 'Lying around' the workshop so to speak.
I chose EMS because thats what he recommended, he uses it on his heavily modified GTR, which will be out soon :)
Can you tell me whats wrong (or good) with EMS? (seriously because I just dont know about aftermarket ECU's)
https://www.sau.com.au/forums/topic/44775-neo-powered-r33/#findComment-915032
I "know" a guy up here that did a Neo into a 33 and he said it was a nightmare to fit the 33 engine wiring harness to a Neo. I'll admit this guy was no brain surgeon but there is plenty of differences apparently, not just engine but body related as well.
DezertEagle, I asume you don't have the Neo harness? Thats why you chose aftermarket?
Anyway, good luck with it!
https://www.sau.com.au/forums/topic/44775-neo-powered-r33/#findComment-915078
Yeh my uncle told me it wouldnt work, and so I'm going aftermarket computer :P He has done many a transplant in the past (they might as well do one everyday) so they have alot of experience
https://www.sau.com.au/forums/topic/44775-neo-powered-r33/#findComment-915223
Sorry I was talking about the big car his uncles got that will be out soon, he mentions it in post 4
Wow you know about it?!
Yeh I dont know much about cars really haha, but he said he expects like 700kw?
Just know how to drive them and basic things to make them go fast, I just take it to him and he does what he reckons is best..... of course I get 'Family rates' (better then mates rates I guess) thats why I'm doing all this
https://www.sau.com.au/forums/topic/44775-neo-powered-r33/#findComment-915633
hey guys
well i just got my car back from the workshop not long ago i also did the rb25det neo converstion into my r33 let me tell you it was a headache. its getting dynoed this weekend,i also use the ems stinger and ive had no problems with it all though a lot of other workshops say that its utter crap and i should get a power fc
but the stinger is not bad.
anyways good luck hope every thing goes well
ibz23q
https://www.sau.com.au/forums/topic/44775-neo-powered-r33/#findComment-923083
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
