Hmm, maybe I should enter the beast. Should be run in by then. With Reece, Liz, me and prob Dave we just need Cassbo to make it a reunion tour!
Yes! Indeed you should. It's been a while!
It might be tight but my Riceline may be running come late October :D
Are skids allowed?
We are not allowed to drift the course, link up corners or keep your foot in it burnouts. But tyre slippage around such tight courses is to be expected. These are rules from insurance not us.
Yep definately not our choice... We <3 skids!
it's a shame really.
That's the reason I started going these.
Get the burnouts off the street and all.
Can't fight insurance though :(
It is an interesting rule they have created but we must operate within their regulations.
It does not take away the fun of the day :) Its still a cheap bit of fun :yes:
I think people might be getting too concerned about the change.
As I understand it the clarification was that this is a motorkhana, not a drift event.
So if you go out to link the whole course and do a few helis that's not OK.
If you spin the wheels launching, lock the wheels turning around a cone or even sliding around a given cone or 2 that would be OK. It's still great fun, and a great event for people to do their first motorsport event because it's easy on the car :)
  • Like 2
To confirm the changes,
I am quite concerned actually, as all I have been doing over the last two texi events were skids and linking corners. How strict will these rules apply to suppress ‘induced power sliding’?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
