What's the plans for squeeze? Full WON REVO set up?
Fantastic build so far... damn those gudgeon pins are thick!
Much buggering about bolting an rb head and crank to the rd28 block?
Cheers
J.
No gas yet.
No real hassle on the block.
Picked all this gear up today.
  • Like 2
I'm pretty keen to see what the ass end looks like once you have shaken it down and get it to a point where it will hook up well.
Cheers
J.
Will be interesting. The RIPS GTR sixties hard on standard gear but has slicks to take up some of the load at the hit.
The support Haltech give their customers is outstanding and they're genuinely interested about developing the product to better suit my application. From the top down they're a great bunch.
They still help me out with my clunky old E11
Spent a few hours stripping stuff out of the car last night. Every time I remove a panel or undo a bolt there's another mile of wiring or another module, controller or motor to be removed. No wonder these things are heavy.
Also started trying to work out how the tyres are going to fit. Right now, they're not going to but we can fix that.
