Hey, basically ive recently had my 32gtr fitted with a link g4 ecu and had it custom tuned by east coast customs in brisbane. Orginilly when i picked it up i had a lot of issues with car hesitating when i accelerated when it was at idle and under load. So i took it back and they eventually sorted it out. But since I got it tuned its gotten pretty bad on fuel (before the tune i was getting around 280-300 odd kms out of a tank) im getting around 200kms a tank now. Which to me seems wrong, the car is basically stock with an catback, splitfire coils, pod filters, boost controller and now the tune. Im not really sure what to do, it seems to be running fine and the tuner told me when i was speaking to him that hed disabled the o2 sensors and being a link ecu the afms are disabled. So im looking for opinions on what i should be getting per tank and if the tune is out of wack and making it chew the juice or if something else might be causing it.
To be fair, it should be possible (in fact it absolutely is possible) to tune the car to give better fuel consumption without closed loop than with. If the car is not running closed loop and it is giving really bad consumption numbers, then either tune is crook, or something is wrong (AFM, water temp sensor, just about every page of Ron's thread). If the car is already running closed loop, then it is probably the narrowband O2 sensor that is stuffed.
See your tuner and see what they say. If they have no positive ideas find another tuner. And measure your fuel consumption in litres per 100km so you know exactly where you are.
  • Like 1
That is terrible consumption.
As its a map sensor ecu, a boost leak wouldn't affect the tune, so it really sounds like it's running way too rich due to a poor tune.
The fact you picked it up the first time with drivability issues is a warning sign, and the tune still seems bad.
Ad GTSBoy said you should be able yo get better consumption with a properly tuned ecu.
Your options are take it back for fora third shot, go somewhere else, or get a wideband and tune it yourself (just the low load and cruise areas).
I'm getting 400kms out of a tank in an r32 Gtr that has had the factory ecu remapped, so I'd be taking it to another tuner cause this one has got it wrong
Should also be making a lot more then 164kw
Find another tuner mate, 164kw out of a GTR with steel wheel turbos and a link is pathetic. More than likely just upped the boost and pulled mass amounts of timing across the board. Do you have a timing/fuel map we can have a quick look at? You are about 80-100kw short of the norm with those mods.
Guys, stop quoting km per tank. It's a meaningless figure because everybody chickens out and fills up at different times. There could be 10-15L left in the tank when you fill up which is going to skew the figures in a big way.
L/100km is the only true measure. I get about 12.5L/100km around the city driving with a bit of boost. If I really baby it then it's closer to 11L/100km. Best ever was 9.3L/100km which was 100% freeway driving.
The main reason i went there was because id heard good things but Yeah i was pretty disappointed with power figure that it made not to mention how bad it is on fuel. If i could go back i definitely wouldnt of got them to tune it. I might take it back tomorrow and see what they have to say about it all, hopefully they'll be able to sort it out so i dont have to spend double the money i should.
It's always going to be weird going back and criticising their tune. They can make all kinds of excuses etc.
Ask if they feel it's a reasonable and comparable power figure and consumption.
If they have any idea why consumptions so high.
If they have any concerns or suggestions regarding your car.
You can't just go in and hammer them and expect them to somehow whip out an awesome tune.
I get 11L/100 regular driving and have got as low as 9.2L/100 driving from St Clair to Orange and back with some DD when I got back with a little over 1/4 tank left
15psi with what is essentially a stock car I get 260rwkw, so there is deffenintly something wrong with the car/tune
What cat have you got ?, I picked up a heap of economy when replacing the compliance cat with a metal high flow cat
There are a heap of things you can do to get better economy
I dont plan on going in and kicking and screaming, every time I went in when it was hesitating they were happy to help. So im sure they will have another look at it and try to sort it out.
Yeah the cat is just the shitty compliance one, Ive been planning to replace it for a while. If there was any issues with how the car was running i imagine they would have mentioned something.
no 02 and no wideband isn't that an issue impacting fuel economy in itself?
No.
The O2 sensor just trims the fuel.for slight changes over time. If It was just tuned it should be fine .
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
