How long is that group buy pricing available for Pete?
Only just found the thread... wish I found it a couple of months ago :(
Just about to pick up my 32R from tuning with -5s on e85 flex fuel setup, but would happily send it back in to the workshop in the new year for vcam style setup...
Cheers
  • 4 weeks later...
I just realized that using this method it would be possible to also add vct to the exhaust cam.
Of course it would need an actual exhaust cam and would double the price but surely it would be good.
Also would be able to add vct on exhaust to rb25s.
The other obvious thing is the requirement for an ecu running a crank trigger.
Cmon someone. Do it!
i asked that a few months ago and the answer was yea that would be easy
problem is it costs alot and they only sell a few of these
  • Like 1
You may know the answer to this. Is the nose of a RB26 cam the same as a RB 25 cam? If it is, I wouldn't mind using the cam I have in there ATM (260 at 10.85), that way I wouldn't have to reset clearances again.
I might take a treck out there and see what the results were.
Can update that the Unigroup car that this kit was being used on was just about to have the cam covers bolted back into place after install. Hopefully next week they have an overlay.
Basic setup was a 2.6, 6266 open scroll, 250 @ 9.15 exhaust cam, E85.
  • Like 1
  • 4 weeks later...
  • 1 month later...
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
