hi guys,
I'm a newbie in R33 suspensions area..
I would like to ask a question about R33 springs..
last month, I've bought 4pcs Tein Lowering Springs from someone via online..
he said those springs could fit on R33 GTST or R34 GTT stock shocks..
because of my car is R33 GTST so I thought there were not problem at all..
then when my mechanic tried to place those springs into my stock shock, those are not fit..
those springs are too short for my stock shocks..
my question is, where's the problem?
are those springs has been cut?
or R33 GTST and R34 GTT are not having the same springs type or size?
cheers guys..
https://www.sau.com.au/forums/topic/448904-r33-or-r34-tein-lowering-springs/
Im taking a guess here, but i reckon your mechanic just meant that stock shocks do not support lowering springs. "springs too short for shocks"
You bought lowering springs, hence why he said that.
That being said, if you are keen on using the springs on stock shocks, its 100% compatible, with the only down side being your shocks sit half way compressed.
It's still better than doing it the ghetto way (people with cut/heated springs on stock shocks)
Edited by Deza3000
You probably bought springs for aftermarket dampers/struts. Did you get the spring diameters?
no I don't get the diameter, but maybe I can measure it..
is the R33 GTST and R34 GTT have the same type and size for springs?
I just guess my springs have cut before so it makes not fit for the stock shocks..
Im pretty sure the spring types are the same but the shocks would be different, cause r34 use both fork types and eyelet type shocks where as r33 just use eyelet?
Anyways as i stated before, you must have purchased lowering springs, hence why your mechanic says the springs are "too short", cause they are lowering springs. The only way to lower a car on springs is to buy springs shorter than the factory springs....which is what you have done. Factory shocks are built for taller springs, however most people still use factory shocks on lowering springs anyway so you should be fine. If you plan on doing some track work then id recommend getting some good shocks e.g. bilstein or kyb. It will still work with factory shocks, you will just have a rough ride with a chance of bottoming out.
you didn't buy them off the seller on SAU by any chance did you? the guy that was selling Tein lowering springs for r33/34 that he said have been cut....? becuaee if you did then yes it would be safe to assume they have been cut...should be easy enough to see anyway
yeah, lowering spring still fit with the factory shocks..
but if it did not fit, the only possible way is the springs have been cut..
he did not say anything about cut the springs..
when my mechanic said "too short", we were realised there's cut on the springs..
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
