I will be emailing kelford later today, thanks for the info.
And sorry I pissed off lithium that much... Lots of info, thanks guys! Bottom line is we can't really compare any camshaft from different brand because they are all measured differently.
Well no, they are all measured the same, you just have to know how to read the cam card
Cams aren't really that hard and people way over think them, IMO you choose a cam to suit the application/intended use of the engine
You also can not choose a cam for turbo because it worked in a NA, they are two different animals and need to be designed and built that way, simple explanation is NA needs air velocity turbos need air volume, that is the simplest explanation and as much as I can go a lot deeper in to this this thread is about cams, not head design intake designs exhaust design etc etc
  • Like 1
They quote 50 thou and 1mm. They are different values. They know what they are doing ;)
Yes you are right. I was looking at the valve lift curve which has them marked as the same thing. But the tables to the left show them separately. For these cams there are 4 degrees difference between the durations at 1mm and at 50 thou.
26_a_in_260_915_ex_252_915_32_33_e.pdf
26_b_260_915_32_33_e.pdf
RB26DETT_256-925_3233_e.pdf
If you have a 1:1 ratio of exhaust manifold back pressure to boost pressure (or better) choosing an NA cam is a good place to start!
True.....but when you say NA cam what you really mean is standard, OEM spec NA cam. Not a hot NA cam.
I mean a hot NA cam... big duration and lift.
I'm not sure I follow you. In order to minimise reversion of hot exhaust gas into the cylinder you want to keep total duration under control and you certainly want to minimise overlap - compared to what you would do for an NA engine. Are you sure you don't mean the exact opposite of what you said?
Cam talk rules. Can go on forever and get nowhere fast.
The one difference with double overhead cams is that overlap can be adjusted. So perhaps an aggressive na cam can be dialled back in to something more sensible with the turbo.
Cams are, more than most things, an exercise in matching lift/duration to all the other stuff you have going on (rev range, turbo, CR, etc etc etc). A 272 may be an absolute weapon on an RB30/26 but hopeless on a 26. I don't know I haven't tried one. My limited experience was to go from Poncam B's to a 256/252 combination on a 26. Car made less power on an extra pound boost but was quicker. The biggest difference was in the low to mid range. So based on that extrapolating to 272 I cant reconcile it with what I had.
Longer duration move your torque up the rpm range, which is more power. Careful cam selection can get you a wider torque curve which is what everyone is chasing.
The caveat was just to remind people that duration is measured at a small amount of lift. How much lift affects how much duration. Something to be mind full of so everything is apples and apples.
Ultimately if shorter duration made more horsepower you would keep stock cams.
What was the lift and love centres on the 256/252 cams, also did you check cam/bucket clearnces
on mine both sets of cams where setup on the dyno to give best response and most linear power graph as possible, not just dropped in and that'll do
If the stock cams had more lift I would have found a set to replace the Poncams, I may have found a lobe which [email protected], if this can be scaled down to a 32mm base and fitted to an RB stick it will be :thumbsup:
I am very sure, PM me if you like.
When boost pressure is higher than exhaust manifold back pressure (very few other than flat out race engines get this right) then you want overlap.
Ahhh, but now I see what you mean by "or better". You mean less ex manifold pressure than boost pressure. You see, seeing as that is relevant to approximately zero percent of us, I assumed you mean the other way around.
Continue on as you were!
So you have a result of a race engine which has less exhaust manifold pressure the boost pressure cause that is something I would like to see proof of, ie a data log
Higher duration cams on any turbo application is not the best way of building them unless you want it to rev it to the moon which defeats the purpose of turbo charging
Duration is the working range of your engine, different turbos can blur this and unfortunately good is the enemy of better
this is a theory I have had since I first started building turbos engines back in the 90s and was proven to me when we turbo charged a mates 20v R1 and I have the reason why but I'm gonna let you try and figure it out for your selves
When I get to it I will measure it not to prove it to anyone but having higher boost than manifold pressure is what I want to achieve and I won't know without measuring.
overlap will depend on your static comp ratio.
no point in having huge overlap unless you have 11:1 comp or something crazy.
its all about matching everything to where you want the power to be made.
either way
lots of lift is good on these motors
btw lots is a relative term.
unless someone with more money than I can develop an aftermarket head for rbs with raised ports larger cam journals that are raised and bigger diameter lifters.
so we can see what .600+ thou lift does
I've pesonnaly never seen it happen and can't imagine it's possible and I have been involved in a few turbo charged race car builds, the only way to lower manifold pressure is bigger exhaust housing and bigger turbine wheel, both of which induce lag, the turbine would need to be bigger then the comp wheel for starters
Then add to that you want to use high duration cams, I hope your happy to rev this thing past 10k chase my guess is your going to have to
The only reaso you use high duration cams is if you want to increase your high range
What can be considered as high duration ? Is it dependant on the engine make or theres some sort of concensus ?
You went with TYPE-R, if you could, wouldn't you have prefered if it came with a higher lift ? like 10.25 ?
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
