he is putting an rb in a skyline
what is there to understand?
I can't find the answer im looking for on search :(, are you saying that i need to find an r33 that had the factory rb20de? or would a na r32 tailshaft work also?
RB20E not RB20DE (in R33s that is). They are as rare as hen's teeth in Australia though. The only ones that ever came in came as mistakes. No-one in their right mind would ever want one. So finding the tailshaft out of one these days would be next to impossible.
mattymatty. Search using google. Don't search ANY forum ANYWHERE using the in-built search function. Tell google you want to search sau.com.au and it will search just that site, and search properly. Literally EVERY question you can come up with has probably been asked here before. Except perhaps about fitting an RB20 into a boat.
Here's the thing. When putting RB25 turbo box into R32 you have to get the front half of the front half (note the repetition is NOT a mistake) of the R33 tailshaft and graft it onto the shortened front half of the R32 tailshaft. If you want to do it the other way around, then you just have to do the opposite of what I just said. It would be money better spent on getting an RB25 instead of an RB20, but there you go.
And hardsteppa. Just f**k off mate.
Edited by GTSBoy
The other problem with using the glass rb20 box is the extra weight of the car.
So its good you got the rb20 cheap. But putting the 20 box in is really the troublesome thing, in that it creates more work for a box that will just break.
(The rb20 will just be slow, so no harm done, but the box is weak and will likely break)
How long would you have to wait it get the cash to buy an r33 box? During that time you could drop the engine in and get it running(just the engine, so whatever rewiring is required) Then box simply bolts in and you can chirp second and make whooshing noises past bus stops all day.
  • Like 1
i did try google but all that came up was 240sx forums. Thank you guys for your help, I think I will take the 33 gearbox advice. I got it thrown in with the engine anyway so I might just sell that and look for a 25 box while I set everything else up. I got the engine way to cheap and way to many parts to get the thing running to consider a 25 engine though so I will pursue through the hate and use that. Thanks all
I'd like to throw my two cents in.
RB20 box is shorter than RB25 hence the different tailshaft lenghts. But since you have a welder you can fabricate/modify the tailshaft using RB20 yoke.
Engine mounts, should use the R33 ones I suppose. In R31s you use the R31 mounts for RB20/RB25 conversions or the engine sits weird.
Best is to dummy mount the engine and gearbox and start measuring.
Also, since you can weld, make a Gibson-style exhaust manifold.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
