I have a rb25det with basic mods, bigger turbo, 7psi external gate. For some reason when it boosts, the intercooler pipe pops off which is connected to the turbo. I got t clamps and it still does it? Is my intercooler blocked, i cant think why this would be happening. thanks guys
  • Like 1
https://www.sau.com.au/forums/topic/449703-intercooler-pipe-keeps-popping-off/
Not sure what boost?
lol
so you could be running a bazillion psi and thats your problem?
lol
get some T clamps, they are the way to go, if you cbf taking the turbo off and running a bead of weld around it, then make sure you've got a nice fitment, strong T clamp, and use a proper silicon hose, not some cheap ebay 5 dollary!
well if you drive along and you hit boost and the car pulls harder then your intercooler isnt blocked. in saying that its not "blocked" it might be partially blocked.
but i would have to agree with some of these other guys, cleary your running Fark loads of boost! if its still popping off a t clamp. install boost controller and report back :)
I had the waste gate hooked up wrong, wastegate is now opening but doesn't build much boost and runs like crap. Its a standard rb25det with a chinese t3/t4 type turbo. It is not tuned for the turbo, would this be why. Do you think just putting a standard 25det turbo would be a good idea. thanks guys
Yes.
Not being tuned is the blatantly obvious reason why it runs like crap.
Coupled with crap turbo. And potential damage caused by your mad over boost sessions.
Putting stock turbo back on would make your life very easy.
Edited by Ben C34
where do people find these cars... I swear once a week there's a thread from someone buying a car that has a T3/T4 Ling long ebay special, stainless highmount, boost leaking FFP and a standard ECU.... and they're asking us why it runs like shite if at all
  • Like 1
For every person we hear from there are probably 20 we don't know about. Eventually they replace all the decent stock parts with fail parts, then sell the car after they realise it's farked.
Those T bolt clamps are crap.
Two norma clamps may hold it to 15psi or so, more than that it needs a lip.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
