Ryco filters are ok;
This is from the M35 info thread, looks like your HR uses the same filters as VQs
Oil filter is Ryco Z436 or Z445 : Nismo (Veruspeed) 15208-RN010 : K&N: HP-1008 : Amsoil Ea012
z445 - seal diameter 63mm, height - 65mm, seam diameter - 68mm, thread size - M20-x1.5-6Hmm
z436 - seal diameter 64mm, height - 66mm, seam diameter - 69.50mm, thread size - M20-x1.5-6Hmm
So either of the rycos is ok since they're almost the same size, IIRC one is cheaper.
  • Like 1
https://www.sau.com.au/forums/topic/450274-engine-oil/#findComment-7418379
Are Ryco oil filters any good ? What's the correct part number for the VQ35HR ? Some said Z445 and some said Z436 ?
For some reason, the ryco webpage lists a Z436 for the V35, but Z445 for every other vehicle with the same engine, including the 350Z.
Most other sources list the Z445. The Z547 also fits, but is 20mm longer
https://www.sau.com.au/forums/topic/450274-engine-oil/#findComment-7418579
  • 8 months later...
I've got about another 250kms left until I'll be due for the first service since I've owned my V36.
I've been looking at the Martini Racing Oil line, but can't seem to workout where to buy it.
What are the current recommended good quality oils I should be looking into?
https://www.sau.com.au/forums/topic/450274-engine-oil/#findComment-7585747
That's a fair point, but I bet these days its unlikely any of the oils sold are likely going to cause an engine to self destruct.
I ended up referring to another forum bobistheoilguy.com and think I'll settle with an oil I can readily pick up from autobarn etc relatively cheap at $85 for 5L that seems to have good feedback from used oil analysis tests and users in general. Looks like I will settle with Liqui-Moly 5w30 Leichtluft special LL (seems Nissan run liqui-moly in their bathurst 12H GTR as well) and I'll run genuine filters.
https://www.sau.com.au/forums/topic/450274-engine-oil/#findComment-7586405
I have been using Castrol Edge 5W-30 for years.. I just wait for one of the local auto stores to have a special on for around $40/5L and buy about 4 of them.. I use the same oil in my wife's J31 Maxima.
https://www.sau.com.au/forums/topic/450274-engine-oil/#findComment-7586463
Maybe ill get crucified for this but I've used Castrol Edge 5w-30 for 4 services and found that the engine wasn't as smooth and fuel consumption was a tad worse compared to the Motul oil I am using now. Could be due to other factors that I am unaware of. So now I am sticking to Motul. But I am open to suggestions and trying out other oils as well.
I think some people swear by what they use cause their mechanics use specific oils and tell them how good they are. At the end of the day comes down to personal preference....imo anyway
Edited by colin.ssc
  • Like 1
https://www.sau.com.au/forums/topic/450274-engine-oil/#findComment-7586499
yeah, I think a lot is personal preference. in my last car I tried lots of different oils (of the same weight), and couldn't detect any difference between any of them in terms of performance or economy, so these days I just stick with a reasonable quality oil that doesn't cost too much.
https://www.sau.com.au/forums/topic/450274-engine-oil/#findComment-7586807
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
