Duncan's Race Car - The Most Overdue Build Thread On Sau
I will continue to lurk and will (work permitting) come and see this puppy in the flesh at a local track, ensure you post up dates for events mate.
Good work from Neil with the assist.
Good work from you with the loaded invites.
Rock and Roll
actually there are a bunch of good quality gauges that need a new home....I'll post up when they are ready to go. Even better if someone is putting them in a track car because they come pre mounted and pre wired in a carbon fibre centre panel.
Individual gauges were OK but I definitely should have made the move to a single dash long ago with how I use the car.
  • Like 1
hahah don't worry I'll be happy to have them go to a good home :)
Speaking of wiring, can someone with a (working, or at least wired up :)) R32 do a quick test for me?
Under the bonnet in the fuse/relay box is a brown relay labeld H/LAMP. Disconnect that relay (unplug it from its loom below). Then, try
1. Low beam headlights should work
2. High beam headlights on should work
3. Flick high beams should not work.
The wiring for the headlight switches is crazy complex for my little brain, so I just want to check my understanding that the relay only controls high beam flicking.
OK, so Neil dropped by to help mount the various new toys around the car, but I got so damn sick of his complaining "there's shit f**king everywhere in this garage" so we put some stuff back together instead. Actually, since everything is shiny and new (or at least just shiny), it mostly went together pretty quickly. Biggest issue of course was not having anything the right sized pieces to press in the large bushes, in the end the rear subframe ones had to wait
rear arms all have bushes and ball joints (except the LCA inner where it turns out whiteline have 2 parts listed, and I got the wrong one...)
rear hubs back together. Neil had to do these since he's the only one old enough to remember drum brakes (and carburettors too, whatever they are)
front suspension all ready to go with new bearings, ball joints and bushes.
made some progress on Neil's Radical's wiring this weekend, but stuff all on my car.
I did get this snazzy pressing kit of ebay which made short work of the subframe bushes http://www.ebay.com.au/itm/231667756034
Just put a correctly sized sleeve above and below the bush
turn the handle (OK, lots, and hard), and it is done
voila
  • Like 2
Well, it was the cheapest one around and they are crappy castings, you can certainly buy similar but better quality kits for 400+. but even so they are still 5mm cast iron so I can't see any problem. Certainly better than abusing big sockets like I have been. I just couldn't readily get the subframe into the press because the shape is horrible, so using just the threaded rod worked a treat
Good to get you out of your garage and into mine. Thanks for the 7.5 hours work on Sunday.
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
