Duncan's Race Car - The Most Overdue Build Thread On Sau
so....haven't really been home over the break so I've made SFA progress.
I did spend a couple of happy hours with a heat gun, saving a massing 0.9kg removing the last of the tar....
  • Like 1
Good question!
Homologated weight for a 32 GTR is 1430kg
Production Cars (3E) say 1400-1499kg cars can have a 5% weight reduction, and then you have to add 85kg, so minimum weight for Production car is 1445 including driver.
Targa regs specify 1560 including 150kg for 2 crew and safety gear so 1410 for the car alone
At it's last corner weighting it was 1397 (half fuel tank) +90kg driver = 1487. Rally gear like spare tyre was not on board at the time. Both sets of regs are actually very restrictive about what can be removed so I can't see it ever getting to minimum weight without some dedicated cheating.
I'll post up what it is after the rebuild and 1kg of extra tar being removed but I can't see it being a problem.
ummm yeah. this thread was about the car's progress not me but I guess they are related.
Basically I've decided to tick an item off my bucket list and enter the Bathurst 6 hour race at Easter. The GTR wasn't eligible (due to age) and even if it was I wasn't confident how it would go flat out for 6 hours so I figured I would use someone else's car instead.
So, I did a test day in this dirty emo 9 on Monday, it went OK although it was surprisingly different in feel to the GTR and I'll need more seat time to be comfortable. Even though they can run 1.2bar boost (vs 0.8 in the GTR) they make a little less power; they are of course about 200kg lighter though.
The other part of this decision for me was that it takes a lot of my race budget for the year, so I am not rushing to get the GTR ready for any particular event. Instead both Kel and I have entered the 8 round state hillclimb champs, the first round is at Bathurst in the first week of March.
Put it on the scales. If you could get a fully prepped/caged Evo 9 under 1350kg with fuel I'd be surprised. More likely a 100kg difference.
Taking a punt that this thing will fly, and Fatz will renounce all GTR allegiances then fully convert to Emo status.
I fully understand this logic - except I stupidly purchased half my EMO instead of just doing the smart leasing thing. They are an odd thing to drive - I found you need to basically over-drive them to get some speed out of them. They seem to respond well it it. And they are actually more fun to drive than I was expecting consequently.
But I still don't have any love for them. lol
I haven't driven mine since Nov and probably won't before Bathrust.
Still - like me I'm sure you've already started the count down to the event. Should be a ripper.
yeah mate I saw you were heading there too in the racing thread, should be an excellent event. buying would probably not have been much more expensive but lets face it, there is nothing faster than a borrowed car :devil:
Tim see you at Kempsey...but it's round 3 because Bathurst is 2 events/ 2 rounds over the 2 days.
Dale I did ask what they weight but the exact answer went straight out the other ear; I just remember I was surprised how light it was compared to the GTR
so there's been stuff all progress, I did tidy up the fuel pump cradle and move to e85 safe hose.
I ended up deciding to keep the small lift pump (and the 044 external) although neither are e85 OK, I am going to run the oil additive and carry spare pumps instead. I also did some measuring of fuel pump impact on temps but will post that up in the lift pump thread when I get a second
also did another test day in the emo, they are annoyingly quick little bastards. did a 1.06.2 at wakie on old tyres which is 0.7 faster than I've ever done in the GTR....still not heading permanently to the dark side though, it's nowhere near as much fun.....plus, I picked up some ideas from the data logging that I might try in the gtr anyway.....
If you've got one and competing in it, you're already there.
What's annoying about Evos is they are so competent out of the box.
Is Fatz likely to come out and admit he's had a go too?
  • 1 month later...
lol evos are broken, not for broken men. And FWIW it weighed 1450ish with me onboard after qualy. damn quick little cars though...
Since this thread is about the GTR build not my racing, here is my bathurst 6hrs story in pictures
Practice and Qualy
The race
The crew and only CXC car that finished
  • Like 2
  • 2 months later...
Right, so....been way too long since an actual GTR update, which is not fair because progress has been happening (although not quick).
On the electrical side, I've finished stripping all the looms.
Rear loom complete (in theory) including new main pump and lift pump feeds
Front loom complete on the engine bay side, still some work required at the cabin end. Still a bit to do on the dash/main loom. Only 1 relay and a couple of fuses left under the bonnet as the smartwire will handle almost everything
Also installed the button and wiring for the new kill switch in the driver's door
Also got a new intercom to simplify everything, just needs power and earth and removes the old adapters. Also comes with bluetooth phone for calling in the service fairies.
And finally, sorted LEDs for all lights (except headlights, where I still need to get the housings first)
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
