Duncan's Race Car - The Most Overdue Build Thread On Sau
We paid $31k for ours, 1996 R33 GTS-T with 56000 kays. True M-spec I might add, not a car with add ons after the sale from factory.
Ha Ha yea Duncan it's very amusing trying to explain to them about their cars, I get much enjoyment. One that always pops up is the Power FC, apparently they are junk, but they still get sold for big dollars.
  • Like 1
On 27/08/2022 at 8:44 AM, Duncan said:
Mate, there would be new skylines owners on these forums from American that weren't even born then...
Lol
I hope some Muuurricaaaannnnnn buys mine.
I will then never own a Skyline again (I said that last time, and the time before I said I'll never buy a JDM shit box but ended up my 1st R33, now 2nd)
  • Haha 1
On 8/26/2022 at 2:50 PM, Neil said:
Sorry Ben, let me re-phrase that, I would have to be the longest single ownership person of a Skyline on SAU, Invoice date 06/09/2001.
I have you beat, Nov 99. What was the plate Duncan...HUJ-33 or something wasnt it?
Geez mate, they hadnt much earlier released the R34!
  • 4 weeks later...
Ha, well no progress lately so no updates. Given another upcoming wet summer I've been out on the tractor with the grader blade trying to get some driveway drainage in place, which in itself is an interesting challenge. And once that is done I'll have a few months of weeds to get ahead of for the same reason.
My guess is progress on GTR will be slow until later in the year. Kell is off to Great Tarmac Rally in a couple of weeks with Mel in a shitbox wrx instead.
No work worth updating on the race car, dealing with some minor surface rust / underbody / chipped interior paint etc. As they say in racing, its "good from afar, but far from good".  I'm also updating mounts for rally gear in the boot like spare wheel/jack/toolkit.
On the other hand, the 100m of the 1klm of driveways I have done went awesome in the big rain :)20221008_142439.jpg
The rest, not so much.
  • Like 1
I did a fair bit of prep work before the rain and then we got less than expected and spread out so we actually faired really well, you guys got pumped (you are up blue mountains way yeah?)
We're a bit south of there but same general area. This was the little river behind our place after 50mm of rain (back during the drought it took 150+mm for that)
  • Like 1
  • Sad 1
We had water over our driveway from dam overflowing for the first time ever recently, only a few inches, but it had to fill the dam and overwhelm the overflow first.
This was because our neighbours dam had blocked/spilled over, then he unblocked it so we had the overflow and the spillage coming at the same time plus the rain.
The water table is defs full.
Throw in some side drains on the low side every 50 meters or so
Control scouring with rubble drains, and put in the odd culvert
I build alot of unsealed roads with work, drainage will keep it open longer, but there is only so much drainage can do
erosion-sediment-control-unsealed-roads-field-guide-120410.pdf
Thats f**king awesome, thanks mate. I was just looking at the drains thinking they were going to need some larger rocks to stop erosion in the fast moving/steeper sections too, they are comparably cheap to bring enough of them in.
I've got a grader blade so regular resurfacing is no issue, I do need to bring in a massive amount of roadbase over time if I want to improve the actual surface meaningfully, but it is passable now, even 2wd in the wet
Culverts are a practical issue too....there are 4 places where I could do with them but that is a very expensive job - 2 lengths of pipe, excavator time to dig down, aggregate under them to keep them stable with a proper fall, headwall at both ends and a pit at the entry. For now I've just got a light ditch across the road surface at each location and just fill them back in every now and then.
We did put 2 proper culverts under the main drive - 4 lengths x 600mm pipe...cost about $8k but I've never seen them more than 2/3 full which is a win.
20220129_172959.jpg  Need to do the same under the mid dam road, it goes under all the time
Just had the lower dam overflows dug out, looks like they are 2x300mm which is probably not enough for big rain.
All of which will seem like a hell of a waste of time and money in 18 months when the drought returns and we are watching the bushfires roaring across the hills
  • Haha 2
  • 1 year later...
On 18/10/2022 at 9:15 PM, Roy said:
When does the airstrip go in for the Cessna Bird Dog?
Took me a while to answer that....
Funny thing is, the across the river neighbour did put in an airstrip, built a hanger, and buy a cessna, because strangely they aren't allowed to build a house on the property but there is no problem building an airport terminal :rofl:
They've used in 3 times, once for an attempted landing where they misjudged a little, aborted and missed the trees by so little that new underwear was required. Second time the landing stuck, then a few weeks later the plane left and never returned, so I don't think aircraft noise is going to be an issue.
Funny looking back through the last few posts too, I've spent a heap of time lately redoing the roads  and drains so I guess it is a 2 yearly thing to add to the calendar. Those big drains did overflow in the rain about a month ago so that is pretty disheartening....just a reminder that you can't stop nature I guess.
Uncle Duncan, send me some photos of the creek/drain/culverts, when it's low or dry, and also when it floods if you have any
Do you have an idea of how much water that part of the land and drainage would capture in a heavy fall
Does the whole creek/drain overflow up stream as well as downstream, or are the culverts the bottleneck, or is the water building up past the culverts and stifling the flow, or does the whole road go under
Are the culverts being blocked by dirt or vegetation during the event
A land survey would be handy to see where the upstream water is captured and drains down stream
I can roughly calculate the size of the drain and culverts required and speak to our surveyors and engineers at work to see what options there are
When it comes to culverts and drainage it all comes down to some math to work out what is required
People often underestimate the size of a culvert/drain
In saying this I won't be back at work for a week or so as I had my right shoulder rebuilt 12 days ago
Duncan just needs to start an epic open pit mine, let it store the excess water for him.
Call it a dam and the authorities won't say a word :P
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
