Hey guys,
I'm very new to the forums and i was just wondering if someone could point me in the right direction of what coilovers/springs to get for my R34? Around western Sydney area.
I want it just to look nice. Not too low though....
Edited by 34-GOKU
https://www.sau.com.au/forums/topic/450956-lowering-my-r34-gt-t/
Much has already bee written in this very forum on that topic.
A little more information provided in your post might help (as in.....what's in the car right now, so people know whether modification makes more sense than replacement, etc etc). Or, you could do some searching and reading and probably find the answer yourself.
I have myself used ksports and tien super streets.
Ksports offer much more adjustment (can go REALLY REALLY low, like chassis on the ground low) and fronts are slightly camber adjustable, but they also felt very hard and would be a good track option, but as a daily at the time, was not functional - you will feel everything on the road.
I now have tien SS. No where near as much height adjustment (I have them set as low as possible, and it will only lower by about ~30mm or so) and no camber adjustment, but on the "hardest" spring setting, they are still very soft and perform well for street use (now just a weekender, but have taken it on a skidpan and felt very nice)
Below is the fronts on lowest setting, rears raised by around 20mm.
BC Racing coilovers are an affordable and proven entry level setup. No point in lowering the springs only, your stock shocks will not last. My rear shocks started leaking in just a few months with King Springs.
Also keep in mind that if you do any significant lowering (over about an inch or so) you'll need to start putting in adjustable arms to get enough adjustment in order to correct the suspension geometry. These things tend to escalate... Alternatively you can just run big neg camber and ignore the handling/tyre wear issues like every other lowered car on the road ;)
Above is correct. Front and rear camber arms set me back $120 and $100 respectively, fairly easy to install but bolts will more than likely be rusted/seized and will be super tight to undo. But still I did myself. Plus another $70 for a wheel allignment. Just factor that in because you will destroy your tyres quick, and a new set will cost far more than a decent set of arms.
  • Like 1
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
