Hello
Today I noticed a hairline crack at the base of the radiator filler neck, it trickles a small amount of coolant when driving and for a short while after until the car cools down. it's not losing heaps of coolant but don't want to be driving and have it open up and lose my coolant I'm not going to drive it until it's sorted in case it goes bang big crack.
Just looking at advise as to what I should do,
Is it worth removing the stock one and taking it to a radiator place and get the top tank replaced? $150-250
Or buy a brand new koyorad oem replacment radiator $250 http://www.ebay.com.au/itm/RADIATOR-NISSAN-SKYLINE-R33-R34-93-2001-MANUAL-VEHICLE-KOYO-RADIATOR-/200449233351?pt=AU_Car_Parts_Accessories&hash=item2eabb491c7
The car is used 99.5% on the street so a big expensive racing radiator would be overkill and unnecessary. And don't want a cheap china alloy one either
Anyone been here before what would be the best way to go?
https://www.sau.com.au/forums/topic/450995-radiator-hairline-crack/
Buy a new one. Fix it now and it might just break in another spot later.
Get a new alloy radiator now and less likely to have problems in the future. I bought a Greddy radiator when mine split. Best thing I think I could have done
Yeah I'll get a new one, not really keen on replacing the top tank idea.
I've looked the Blitz 41mm alloy rad and koyo alloy 53mm they are 500-600$ Not sure if it's overkill and a waste of money. Do these fit like oem?
Genuine Nissan.
What do these cost? Couldn't find anything online not sure if anywhere would have one and be able to have it to me within a week
This is dodgy as but I had a mazda bravo way way back when and the top tank split the whole lenght, being young and broke I pulled out the aerodite and put a healthy coat over it till I could afford a new one, 4 years later I replaced it cause it looked dodgy not cuss it was leaking :/
  • Like 1
Solder up the crack or just get a replacement stock radiator from your local shop. It should last another 15 years. I just use stock radiators in my car with the RB30 and it doesn't overheat on track days.
Just fixed a Cracked Honda S2000 Gearbox case that cracked around the drain plug in 3 places (told son not to overtighten it 1000 times before putting the plug back in and what does he do?) with JB Weld. :)
I have heard people are also using it on radiators, but i can tell you his gearbox is not leaking and it saved me from pulling the box out and getting it welded back up again. (or replacing the box)
Dodgy as hell but it worked, dont know about the next gearbox oil change though......
The radiator top tank is plastic remember.
I was advided against repairing it when mine cracked. Especially if you are happy to just to get a cheaper than Jap brand radiator. Sounds like it will be fine for what you need. If you want to spend some money than the Greddy radiator is great. Fits perfectly and shroud fits on nicely
Really up to you but
I'm going to replace the radiator hoses to, would it be a good idea to replace the thermostat while I'm there?
The only Greddy radiator I can find online is $1099.!?
Would there be any cooling issues with the koyo oe replacment? Anyone used one?
If you have the standard clutch fan and shroud (assuming fan works fine), you're better off getting something that can use the shroud.
http://www.perfectrun.jp/src/quick/qui_home.php?qui_cb=101&qui_cmd=cg101008_10102&qui_cpb=0&qui_cat[]=sct_502&submit=GO
Take your pic, then either buy through there, RHDJapan, Import Monster, Nengun, or Jesse Streeter.
The top tank in my Bravo was plastic and it held up for 4 years with aerodite :)
Just looked like arse :/
If you have the standard clutch fan and shroud (assuming fan works fine), you're better off getting something that can use the shroud.=sct_502&submit=GO]http://www.perfectrun.jp/src/quick/qui_home.php?qui_cb=101&qui_cmd=cg101008_10102&qui_cpb=0&qui_cat[]=sct_502&submit=GOTake your pic, then either buy through there, RHDJapan, Import Monster, Nengun, or Jesse Streeter.
Are these instock in aus or need to be sent from japan?
They all say factory air duct cannot be used with this radiator. I'm still using factory airbox is this a problem
What about fenix rads http://www.ebay.com.au/itm/Nissan-Skyline-R33-R34-93-02-Heavy-Duty-Alloy-Fenix-Radiator-/171117111768?pt=AU_Car_Parts_Accessories&hash=item27d75fe9d8 they look quality?
They get shipped from Japan.
You should be concerned about the shroud more than the air duct, but if you want to keep the duct, get OEM.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
