Im halfway through rewatching the 2005 season and it's 100 times more exciting than current f1.
No tyre changes just fuel stops ftw. Fuel is such a better strat than tyres.
Absolutely pump through the fuel these v10's do
Was rubbish. Too many people limping around on flat spotted tyres. Then Ferrari got the rules change because they kept losing. US GP was awesome.
Surely with the technology they have now, they could put an interlock on the gearbox while the fuel gun is in. Fuel gun still in = can't select gears
I dunno, I see the safety reasons behind no refueling, but I think there is a better answer then just doing away with it completely. The gearboxes are electronically controlled, the throttle as well. It seems crazy to me that they were unable to work out some sort of system that stops the car taking off when the fuel gun is still attached. Maybe I'm just missing the real issue. I don't know
Aggroman: did you download the 2005 season? I've sometimes thought about watching some old races, but can never be bothered to
Yeah I've got 89-90 then 2000 to now.
This race is incredible hahahahaha holy shit I now remember why America hates f1
Tells you all you need to know about F1 & Ferrari. Screw the whole show in Seppoland for years to come to "win" a race against Jordan and Minardi. Even then they had to orchestrate the finishing order. Entrenched narrow mindedness is breathtaking.
The chances of Jules surviving are almost nill.
The fact Schumacher is still "alive" comes down to money.
They both have significant brain damage are effectively dead.
It's a horrible thing.
I was thinking the same thing. It's sad and all, but it kind of shits me when they keep saying "he is fighting". No he isn't. His body is just on autopilot. Save the term "fighting" for someone who is conscious and doing everything in their power to get back to some sense of normal as fast as possible (through rehab, etc) rather than just sitting there in bed hoping things improve.
or the Michelin guys could have slowed down for one corner...
  • Like 1
Wasn't the 'plan' that Michelin cars had to run through the pits every lap
I remember being on holidays at a relatives place, staying up by myself just so I could watch the race. Then being very disappointed in what happened
they wanted a chicane to slow down the field as to not cause the issue, other suggestions were for all michellin runners to go to the back of the grid.
it then went to "lets put the chicane in and none of the michelin runners will score points"
Ferrari said no, FIA sided with the fez and that was that
that's one, slightly skewed, interpretation of events.
The FIA made it clear they would not alter the track to suit one tyre manufacturer at the expense of another. Fair enough imo.
They also pointed out they did not have time to design and build a chicane they could ensure would be safe in the time available. Again, sounds fair and resonable.
The Michelin teams had the choices of:
- taking T13 at a speed their equipment could handle,
- running through the pitlane each lap to ensure their drivers could not exceed the limitations of the Michelin tyres,
- flying in a different spec tyre and having some sort of penalty.
Bear in mind there was only 6 Bridgestone shod cars, so even if all of them finished in the top 6 positions, there were still points positions left on the table for the Michelin cars.
The Michelin teams refused all of those options and instead issued an ultimatum to the FIA to install a chicane so they wouldn't lose out to Bridgestone, otherwise they would not run.
Michelin's fault for bringing an unsuitable tyre and for the way they chose to handle the issue. I guess the last word is that Michelin elected to refund all ticket holders and hand out 20,000 tickets to next years GP to avoid litigation from the US fans.
Edited by hrd-hr30
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
