too late now, but ive been using Ace Stream, you install a program like vlc and it plays through it, you can go back to earlier footage if you want, i tend to wind back a minute so it has more time to prebuffer the stream. I think it does take a lot of download though so youll need a decent plan
for next time guys
http://www.livefootballol.com/channel/sky-sports-f1-acestream.html
Hm google reckons that app is malware, interesting. think i'll give it a miss just in case :P
Refuelling and free tyre choice.. that is good. Let's bring back more common sense.....
Currently F1 has too many rules, and is so restrictive. Then they try and manufacture a show that is fake and boring. Prime example: DRS just makes passing a done deal. It's boring. Movable aero should get thrown out, or let everyone do it all of the time (ie to defend as well as pass). You can fiddle with the levels all you like but at the end of the day it's a band-aid that gives the guy behind an advantage that is decided by a committee. It's not 2 guys on a track with the same equipment dueling it out.
I recently watched the 2006 Hungarian race and it was epic. The cars with their beautiful V10s howled, the wings were low and wide, tyres gripped. Yeah, they had traction control (not a fan).. and some time around then grooved tyres came in which was a bit silly.. but the show wasn't as farcical as it is now. I don't even bother watching highlights. Who cares. Drivers aren't racing each other flat out, they are just playing a car management game. I feel really genuinely sorry for those who have taken their whole lives and worked their way through the ranks to be fed this horse shit formula.
Not sure if the reports are accurate but it looks like the limits on fuel flow rate and total fuel usage will remain so I don't see the point in fuel stops or plans to make more noise with higher revs??
yeah thats what i read too and it confused me too...
i guess fuel flow in the pits stops will determine if its worth an extra second or two will be gained by being lighter through out the race...
it also adds more risk in the pit stops though...
Also yeah the DRS things a bit stupid, Kers worked a bit better because both had the option to use/save it...
But yeah nothing beats the aero of the mid 2000's, such beautiful cars
Watching P2 and feeling jealous on two counts.
1) I'm not there and driving
2) I'm too old, "so Jolyon, when you won GP2 did you also get invited to the Prince Albert dinner party as per F1 guys?", "Nah, had to fly back to UK and sit my exam on the Monday"
Just opened Autosport site and what a confused joke F1 is. Bernie back in court being sued...team owners drivers or complaining about different things...surveys about what fans want....it all looks farking ridiculous!
[sigh]
It is farking ridiculous. Teams going bust and massive inequality in income distribution and their way to fix it is to go back to refueling. Genius.
The racing has been pretty good. I did the survey....told them what i think. 60% of cash needs to go equally to all teams and remaining 40% based on WCC position.
Loosen engine freeze and introduce front wing freeze where they only get 6 wing types and floors per season. Ridiculous they limit engines...making them more costly to engineer but they can spend hundreds of thousands of hours on a wing they may not do more than a practice session. Also need 3rd cars for P1 and P2 that young / test drivers run and are free for testing limiting wind tunnel time etc. by bringing 60 hours of in season, cheap testing to every season whilst having more cars on the track.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
