Hi All,
New-ish to the forum – A couple of months ago a good friend of mine bought an R32 GTST Type-M. I instantly fell in love then started looking around at different turbo cars, potential, cost and repairs etc.
This led me to a lot of informative posts on SAU and through that I was set. I wanted a Skyline. I decided that I would like an R32 but they are a bit old and they have no airbags (not that I don’t love them!). The other option was an R33 S2, dual airbags, big, cheap, safe, fast.. You get the idea.
After a bit of looking and a couple of disappointments I found one that looked promising. The only issue was that for the price it wouldn’t last long and it was raining outside so I wouldn’t get a great look at it.
We went to look at it anyway and spent about 2 hours on the wet ground crawling around looking for issues. I found a few small things that needed to be done but it could not be beaten for the price. Two big pain points and requirements the car had to meet were P/S and A/C this had both J
Modifications:
Blitz SE Return Flow Intercooler
Nistune ECU
3” turbo back exhaust to Lukey muffler – Muffler has twin 6cm tips which give it a nice sound without looking OTT
Pedders Extreme Coilovers
Dyno tuned (I believe by “Toshi” on here???)
Splitfire coilpacks
10 pound wastegate spring
It has all the supporting mods to get me more power but I’m happy for now.
List of to do items:
Rocker cover gaskets - ORDERED
Power steering hose replacements (leaks a bit from the top)
Brakes need a service
Oil Change
Coolant Change
New Drivers seat – PICKING UP LATER THIS WEEK
Stereo (undecided on this yet)
Clean small patch of surface rust from boot – THIS WEEKEND
Reseal tail lights
Climate control LED mod
Polish headlights – THIS WEEKEND
Detail engine bay and car
Respray bumpers and bonnet (if they really bother me which they don’t really at the moment)
Fix third brake light (I believe it’s an LED setup?)
Map lights at the windscreen don’t work so troubleshoot that
Clean ACC Valve (Idle valve) as it seems to be fluctuating ever so slightly which is a bit annoying but I’ll live.
Lubricate mirrors, they work fine but are a bit rough
New rims and tires
Shift boot/Ebrake boot – ORDERED
C Spanners for coilovers
Coolant flush/fill
Most importantly, Drive the car!
I have some questions about the car as I’m a noob but I will Google them first and if I don’t find the answer I’ll ask on here.
Thanks for reading guys – Pictures below:
When I picked it up:
I'll get some more photos on the weekend when I get a chance to wash it.
Cheers,
Jacob
https://www.sau.com.au/forums/topic/451368-jacobs-r33-gtst-s2/
  • 6 months later...
I haven't posted here in ages because I didnt think it got approved.
I've tried to whip up a list of what I have done since owning the car but I'm sure I have missed some things. I'll post pictures when I get home because I'm at work now.
  • Caster arm change
  • New rims (XXR 527s)
  • Transmission mount - Not yet installed
  • Reverse light switch - Not yet installed
  • Shift bushing - Not yet installed
  • Radiator bushings - Not yet installed
  • New/Used fan clutch
  • 3” turbo back exhaust to Lukey muffler – Replaced by JJR Turboback now
  • Rocker cover gaskets - Done
  • Brakes need a service - Done
  • Oil Change
  • Coolant Change
  • Stereo – Done
  • Polish headlights – Done and sealant used (12mth life)
  • Detail engine bay and car - Done
  • Map lights – Found issue to be globe placement
  • Clean ACC Valve – Cleaned but still fluctuates sadly
  • Lubricate mirrors, they work fine but are a bit rough – Mirror ended up not working so I repaired this
  • Shift boot/Ebrake boot – Done
  • Apexi AVCR installed
  • Triple gauges installed (Coolant, Oil and boost)
  • Removed Turbo Timer
  • Fixed alarm
  • Fixed auto window winder
  • GTR Wing
  • 2 months later...
Haven't posted here for a while but my car is off the road for another three months so I'll be doing some work to it.
New & Genuine Z32 AFM - Already delivered
Hypergear ATR45SAT - Ordered
Nismo 740CC Injectors - To be ordered when tax comes in
AFR Gauge (AEM UEGO?) - To be ordered when tax comes in
Scottys custom intake - To be ordered next fortnight
Custom intercooler pipes if I need
JEM Tune and fit of random parts
Pics to come.
  • Like 1
Fuel pump came today
A079CB0B-F736-4CAE-B43D-B812BEA0ACE1_zps
F7F5C48F-2151-42A9-ACEE-0DDDF7548755_zps
268E9D0C-23DE-4CB3-B9AA-57F40808B223_zps
Z32 and plug came the other day
206A66FB-09C9-4B30-A0C6-99E79ECCFCA1_zps
3CF6CBD7-9D80-4B5D-9B11-FC0F97BC934C_zps
95ACC7A6-6489-403B-8904-4102DF5C896B_zps
http://s812.photobucket.com/user/kingtube69/media/85F37F44-F70B-4021-B488-196DE8B1012D_zps886foh3n.jpg.html?o=9
For those keen readers, there is an RC battery charger in the background, I have an offroad RC buggy we take out often.
Turbo is due tomorrow or the next day then I'll order an NPC clutch, injectors, intake and a few other shiny bits soon.
I'm having trouble getting hold of someone from NPC to assist with my clutch decision but no one is getting back to me... Their service seems pretty bad.
I've also hit up Kudos for some other shiny bits and waiting for a response.
Intake, Plumback BOV and E85 line comes on Monday
90 Degree reducer for the turbo comes tomorrow or Friday
Turbo comes Friday, Monday or Tuesday
Flywheel bolts, fork boot, alignment tool, TB Gasket, Manifold stud kit (I've done this once before but didn't have the right washers/yolks) and gearbox seal kit comes Tomorrow of Friday.
Stay tuned for DIYs, Progress pics etc.
I've tried to keep the packaging for the parts just in case anyone else needs to know the genuine part numbers (Not that there is really anything special here)
Flywheel bolts - Ordered to be used when I do the clutch soon
887D9065-C422-40FF-984C-566FE822D479_zps
Gearbox seal kit - Not sure where two of them go but I'll work it out with the manual when I'm ready
2ED01058-74D9-47C2-B020-277611687970_zps
F84FBC3D-6965-428C-B687-7AB9AF7C850B_zps
8941DDBC-7380-455A-8714-9DBE2DCD5BCB_zps
4743EFE6-06FB-4AF2-8100-DEBA602669FF_zps
Throttle body gasket - Ordered as there isn't currently one
B1E03F5E-9AD4-489D-85F1-D16266DFF666_zps
Clutch alignment tool - MIA Kudos forgot to deliver by the looks of it?
Manifold stud, yolk and nut (deez nuts) set - The back story to this is that when I purchased the car, it had 4 snapped studs and so quite a few yolks were missing. While I have the turbo off, I thought it might be worth changing the nuts and yolks to the correct items. Manifold studs will be saved for another venture.
1FC71774-1D8F-4E7F-A7DF-41058FB65997_zps
39242C91-4CD5-4D43-B99B-B00A83A684A3_zps
Clutch fork boot - Current one is buggered
567B8BC2-F80C-4963-B287-56EA345D3115_zps
Things still to come
Turbo from Stao (Hypergear)
Kompact Plumback BOV
Intake Pipe from Scott
E85 Line from Scott
Things I still need to order
Turbo to manifold studs NPC/EXEDY Clutch Replacement Machined Flywheel Pivot ball (Nismo Upgraded) Slave Cylinder Fluids for Clutch Change 740CC Nismo Injectors
My planned end date for this is the 10th of November - I would like to have it tuned etc before this date
I have Wednesday next week off so expect some action shots coming
Thinking of going NPC Cushioned Button clutch, Redline Lightweight Shockproof, GKTECH slave etc etc etc
A plan I had recently was to make a plug which means I can quickly change between Z32 and the standard AFM when it goes to JEM for tuning. On end will be the standard wiring and the other which connects to the R33 AFM will be as normal but I'll have a conversion one that connects to the Z32 AFM also. I'll do a diagram/pics when I'm ready.
Re the AFM plug, I've done my stagea the same way. Just splice the Z32 plug into the existing loom and keep the existing plug instead of cutting and replacing. with a PFC it is literally as easy as unplugging one, plugging in the other, and changing the setting in PFC.
That's an even better idea, I don't know why I didn't think of that. I've been looking at how to do it for Nistunes and it looks to difficult that I thought I better just leave it to JEM to do
Put my new seats in tonight and cleaned the interior - some old v new pics below
09DCA23E-84E9-4221-BB1D-3FDA25D124F4_zps
693F122A-6381-4C40-96FF-C90F31CD6604_zps
82692345-6ADF-4706-B2F2-5A336FAB6AC8_zps
F34E7EA8-CAEC-4AFA-8018-0C48BDF0601D_zps
I did have an issue where the seat belt clippy thingies were wrong between the two sets, I just unbolted and swapped them out.
Selling the old seats for a case of beer tomorrow
I used this as a chance to thoroughly clean the interior
0BFFCBB5-8476-432E-87AF-5D0C69213CC2_zps
E44338BB-B9BD-4A39-8738-A632DB63A80F_zps
I also spoke to Andrew from Kudos who had a clutch alignment tool couriered to me today.
423856B1-26FF-4A49-BCB5-FD96DD55E2B5_zps
I tossed up between doing the manifold yolks and nuts tonight but I can't be bothered. I think I'll just do it all when the turbo arrives.
About three months ago I resealed and rust proofed my whole boot using some different tips from others on here. Doesn't leak one but now!
9682EFC0-F9A4-4753-B77F-39862E11C761_zps
AE224833-94C2-4665-9FC7-D90F5ECEF623_zps
I'm ordering some interior screws this week so I can put the boot back together after I change the fuel pump and do the relay upgrade.
I'll be ordering my new clutch from Garage 7 on Wednesday next week also.
Edited by kingtube69
So I removed my turbo heat shield a while back because there was something rattling around in it. Today I drilled out the spot welds and found what the cause was....
C39BA353-7871-4970-B013-7FC6419E859B_zps
0C091763-9EC6-4309-93BA-AA0AA354BB95_zps
The BOV gasket was in there, I have NFI how the previous owner managed that.
There was also a massive exhaust leak which I fixed shortly after owning the car.
90 Degree 2" to 2.5" Reducer
0B8CC3EB-7C7B-4BBC-97FE-AB4BA94C773E_zps
BOV
EB307B40-6D7B-41FA-8140-D24CFE71D736_zps
7FD18349-6775-4ADE-832C-2FBF1CC3E4AC_zps
HFM Big Bore Slave
8AD7F6D7-7A92-4010-BCE8-409D773BC9B3_zps
The shiny bits - I'm so happy with the intake pipe. Scott even gave me the silicon joiners and other silicone hoses needed.
8FDF67EB-7C9E-4BAA-90D5-956BE97A5A92_zps
Turbo is confirmed to be delivered on Thursday and I'll order some more stuff tonight.
  • Like 1
Booked in my tune with JEM for about two months from now which gives me heaps of time to get all the work I need to get done sorted.
I agreed that they will do the tune, AFM and the Injectors for me. I've left a bit in the kitty to cover me for any custom work I want them to do or any "Fix Ups"
I started doing my fuel pump rewire tonight but am yet to finish as I need to do the pump change at the same time..
Using Cal's post from a while back.
Finished the wiring for the new pump tonight. It needs to be tidied up a bit but it works, looks reasonably neat etc etc etc
I made a video of the "Angry Fuel Pump Mod" and some pics are below also
20A182DD-1F79-4672-B0EE-5A2DC08CDBCE_zps
9F59623F-7D37-433C-A910-D2729BDE961C_zps
EA1C14F7-7FA5-41FC-99FB-D8707486C53F_zps
C8B51A8E-8757-4D5A-B12B-E63E454DFCD4_zps
Ran out of cable sleeving :(
Anyway, Tomorrow I'll get neck deep in fuel (30L or so) and swap out the fuel pump.
  • Like 1
After seeing some information in another post it looks like I'll have to alter this relay setup. The relay won't be happy with the power its getting so I may have to run a solid state relay to energize the coil of the pump relay which I installed. That or bypass the standard ECU control altogether which I really don't want to do.
Finished off my fuel pump work tonight The pump wasn't that hard to do at all. I struggled with the stupid collar more than anything. I also took some more pictures of the turbo below.
Not a lot of people are commenting here but I think it's worthwhile to keep some sort of online log about my car.
DA281CFC-BFD7-4F0A-9476-D7E28BE9EC7C_zps
DE9594C2-65CB-4A6C-B436-C9FFE2FC4B5D_zps
7B5F86B0-2FFF-4957-AEE7-36A958E93F11_zps
3161BEDE-72E8-42B0-9F53-25A97505633B_zps
5D97AC58-5C28-46F3-91E3-CB79F75FDBC2_zps
  • Like 1
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
