Looking good!! What did you end up changing in the fuel pump relay setup compared to what you were originally doing? I was pretty sure a relay will close with only very small voltage, so im curious as to why that wouldnt work.
Look forward to more updates..
Thanks KD,
I was talking to Scott and he mentioned that the relay wont energize properly on the low power coming from the FPCM so it would be better to use a solid state relay then energize the fuel pump relay with that.
I haven't changed it yet but I'll just keep an eye on it all and see how it goes for now!
Stay tuned, I'll be doing the turbo, clutch and a few other things in the next few days
Keep up the posts man it looking good!
I recently installed the same BOV just running stock boost and there was a noticeable improvement in spool up!
Oh - I didn't realise it would also help with spool! I guess its good for me then too :)
The car is running quite rich which I'm guessing has something to do with the new pump as it ran fine before that so I've ordered a fuel pressure gauge to check
After installing the pump the car was running a bit how do you do.
I looked around and spoke to a few people and they mentioned that the stock fuel regulator could be failing or couldn't be keeping up with the return flow.
I ordered a Nismo FPR to keep the stock look and the a gauge and installed it today.
The car seriously runs a lot better - its practically day and night comparison.
I didn't post pics the other day for some reason but
Nismo FPR
27890D23-EECB-45E3-A361-19BE42926930_zps
Gauge
4DE652A0-D61A-415E-8898-B0ED8CD25C61_zps
Wastegate actuator - I need this because I don't want to be running 20 pound all day every day. I know someone else who installed the same actuator with the same turbo without issues.
5D443786-ED3E-4105-A455-D1BBD549A20B_zps
8C92D760-A07B-44B0-843D-698C65CC7771_zps
15E3D799-A70F-4681-BD82-C85091CE2517_zps
22D5EA12-F462-49A2-A70A-56975ECDF6D2_zps
Extra springs of different pressure. Ideally I'll be putting the 15psi spring in and running low boost at wastegate pressure and full boost between 18 and 20.
B686F775-3459-49AE-BD82-6242634D4E79_zps
Manifold studs - I bought them from a place in QLD if I had realised they would drop ship from GCG I would have picked them up from GCG myself considering these took over 3 weeks to get to me.
A9F39C5F-45C7-40DA-828D-62579338ABC0_zps
I also fitted my Nissan Genuine OEM clutch master cylinder then Ordered my HEL Braided clutch line today, Ordering my clutch kit tomorrow night, Nismo pivot etc.. Then we do the clutch Thursday, Friday, Saturday and Sunday.. ON THE FLOOR WITH NO HOIST :O
Pics and updates to come when we do the clutch then turbo shortly after. Then I'll order the injectors and send it for a tune. Completion date for this work is aimed to be the 20th November.
I caved last night and started ripping shit out of the car.
Starter Motor off
Tailshaft marked
Fluid dropped
Shifter out slave off
All connectors removed from box
Breather off the gearbox
I won't have time to work on it tonight but I'll continue tomorrow night for sure.
Progress pictures to come tomorrow.
Soooooooo. Pulled off the clutch, flywheel etc.
Yesterday when I got the gearbox before removing the above I could see what looked like the lightweight flywheel I just bought.... I was right, already had a lightweight flywheel.
E6B00308-CA92-4E55-8286-00BFE1A03011_zps
42AC3289-1213-488C-8E78-775C6443D6C9_zps
C2212A42-53F4-4C88-8D64-1BD4FB5D9C7F_zps
Some weird sort of thread locker?
EF6D6F53-1CEE-4C77-8AF0-40301E8BAB66_zps
This was the old clutch BTW
7108D577-556E-4571-8C45-09F3464C6A82_zps
97C5A35B-1618-46FF-9A40-A9AF9FD35B78_zps
No stamping of part numbers on it and in all honesty, great condition but it just won't keep the power when the car is done.
Rear main - Struggling to get it out but I'll get to it.
1154A378-778A-44E4-9772-60E3A798B7AB_zps
More pictures eventually. I'm going to work on creating a how to using someone else's instructions with their permission and detailed pictures. In particular the top gearbox bolts which are beyond stupid.
I caved in and went back outside to do more work in this terrible heat.
Before
43F5A517-60A2-4FD3-AEB3-75716741C1B8_zps
93202CB9-6063-43DC-9A59-8371AC939911_zps
6463BDF2-E705-43B4-B126-B86FC4AC2173_zps
29CDBC87-7FC0-4AEC-BBBE-3688A0DAC626_zps
ECCD25BD-73E0-4654-9003-EF33A032C286_zps
9104C565-AB18-4AE4-82B4-5D39F7561600_zps
0D9A5E89-826C-47ED-8558-2517145296F0_zps
BBACCE18-D120-426F-8594-599D9BFCB945_zps
Cleaning up/after
5EA6F4A1-70D5-4187-975A-81838ACF7546_zps
3542EB26-D3E5-484B-AE46-67E81A4C803E_zps
0725D444-C10B-49EA-B5FF-E66606712069_zps
Having a very hard time with the spigot bush so I may go buy a removal tool tomorrow or try the grease method (which failed once today)
Looks good so far man. Keep up the hard work! I've yet to do a clutch replacement in mine!
Thanks Dan! I'm not at the stage of getting it back on yet but right now I have no problem doing it on the ground with jack stands and ramps. A hoist would be ideal but not impossible to do as I am.
Borrowed a blokes spigot bush puller and got the stupid thing out today. Tried to get a new one in and messed it up pretty badly so I'll have to try another method of getting it back in tomorrow with a spare I have here.
26E18841-FD62-43CA-A73A-009A2B1481EC_zps
Was going to do a DIY but I didn't take that many pictures because I was too grumpy. I would not do this without a hoist again, If the box was to come off again I would rent a hoist or do it at a mates shop. It's quite hard for me to get the car around until December so I had to go with doing it at home. Got everything back on today and a friend gave me a Wideband to go in the car also which I'll get a bung welded in for when it goes to JEM next month.
A run-down of everything that happened
I broke a spigot bush getting it in like an impatient idiot - So I grabbed my spare, greased it up, chopped up a spare alignment tool and pressed it in. Getting the gearbox itself back on took roughly 45 minutes of struggling with a trolley jack and my brothers help. A note on the torque of the flywheel bolts is by using a flat bit of steel with two holes 4cm apart on the pressure plate bolt and the bell housing bolt and torquing it up using that to hold it. The pressure plate bolts were done by holding it still with our hands.
Torque specs are here for those interested.
Balancer Bolt - 142-152
Flywheel Bolt - 124-152nm
Clutch Bolt - 34-44nm
I did the flywheel to 145nm and the Pressure plate to 38ftlb (yes I know different measurements).
517EE72C-2411-4571-9FE3-C13156622633_zps
916F129B-22E5-442A-B75A-07E738856ED8_zps
B9291788-1313-4E10-B264-CA9DCD8F7BAF_zps
D83C6CA9-C976-4A5F-942A-658E51794F00_zps
02025CD1-0ADC-4E9E-90BC-609F21E4009E_zps
If anyone else wants to do this at home send me a PM and I can help out by answering any questions.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
