What injectors did u go with
Got some used but very low KM 740CC Nismo's - The guy who I bought them off got the same power I am aiming for with the same injectors. I see you have the same injectors on your S2 - How do you find them idling etc and how did the tuner find them to setup?
The tuner had no issues with them. The idle isn't silky smooth but it never was in this car. I doubt its got anything to do with the injectors as they'll sit on afrs of 15 at light cruise no problem. They're good injectors even if they are old tech and can't be beat for ease of install.
Awesome, my idle isn't and never has been perfect either so no big deal.
I got them for cheap as chips with very low kms on them too -I'll get them cleaned for piece of mind too. They are spotless too though with no obvious signs of wear (the seller is here on SAU too :))
E02977CF-4F90-4D73-BFB4-133991E470B1_zps
Tune is booked in for the 20th November so I'll just be cleaning the car and double checking everything before it goes in.
Went to JEM today and spoke to Adam Neish himself.
Got a proper quote and proper expectations
The following is happening when it goes in
- Injectors installed and cleaned
- Z32AFM Installed
- Tune
- FPR setup
- Vacuum leak test
- Boost leak test
- Higher rated plugs
Once all of that is done and it's confirmed that I don't need to buy anything new because something doesn't work or is broken I'll go for a new boost controller but if something doesn't need to be replaced I won't go ahead with it. I'd like to go with a simple boost controller that can be tuned and used easily. The AVCR is overly complicated - I would rather something simple.
Stay tuned for updated but I doubt I'll do anything else until it goes in
Goes to JEM in around 2 weeks now - It's supposed to be pretty decent.
I told JEM my goal is 285RWKW and Stao reckons it's achievable
I'll post DIY information and Dyno information with detailed information on what I have done when it gets back from being tuned :)
EDIT: Was supposed to work on my car this weekend but I helped my mates out instead with their cars so I'll spend more time on it later this week.
Edited by kingtube69
Pretune update
- Changed the oil
- Went to change the actuator but that didn't go too well with changing the spring to a higher rated one. Instead, I'm expressing a Turbosmart one this week sometime
Car developed a slight tick which I'll chase down today or later this week. Doesn't go away with clutch input but goes quiet when I rev it ever so slightly so I would assume something is just loose somewhere.
Really digging deep with a few unexpected issues as of late.
Stay tuned for dyno graph later this week or the next.
Thanks Adm,
Current run down is:
Nismo 740CC Injectors
Z32 Map sensor instead
HyperGear ATR45SAT IWG - Having some pretty bad problems with the wastegate and or actuator. I'll probably end up replacing this turbo next year.
Apexi AVCR
Stock manifolds
3" Exhaust
Blitz Return Flow FMIC
Nismo FPR
Splitfire Coilpacks
Walbro 460LPH
Turbosmart PB BOV
Stock airbox
Haltech Platinum Pro
BP98
As with the dyno graph above, 289RWKW and 550NM torque. The car feels so nice to drive seriously just pulls and pulls and pulls.
Had an issue with smoking, turns out the A/C pipe was sitting on the dump pipe (whoops) This is because the rear housing is larger than the factory one. As I mentioned above Adam said that the wastegate actuator is pretty bad, it's not holding boost very well at all. So I'll look at putting a turbosmart one in the future.
The back story is that it turns out that my ECU is not in fact a Nistune ECU like I was told. Adam at JEM went to flash it and it wouldn't take, pulled open the ECU and no Nistune board so we went Haltech Platinum Pro.
Nistune is meant to be problematic on 33's so its probably a blessing that the board wasn't installed. The graph has torque displayed as foot pounds which makes it well over 600nm. That's huge. What exactly is wrong with the actuator? Looks to be holding boosting OK on the graph but maybe blowing open early hence the additional lag.
Stao said it was a 20PSI actuator, opens on gate pressure at 10psi the tuner said its a bit laggier because of it - Thank you for pointing out that its in ftlb I thought it was NM so that makes it 750NM shit, thats crazy. Really when driving it, the lag isn't too bad it revs up fast enough that its not overly noticeable. Glad i went Haltech also, I have a tablet PC so it would be pretty easy to just flip it to a tablet mode and plug it into the Haltech to have a look.
Already building a list of new parts etc, I'll start buying in a few weeks.
FMIC (Plazmanan maybe?)
FFP 100% Plazmaman
Will get JEM to do the installs of both while there I'll get eflex setup and also get launch control setup on the Haltech
Also going to buy wheels, coilovers and a new diff/shimmed diff but I'll do all that myself.
I also need to get a bolt repaired for my crossmember but that can wait till I get my license back in under 14 days now.
Not much longer left now, I intend on going to Bathurst not this Saturday but the following Saturday and I'll start going to the wetpan as frequently as we used to and go drags a lot more. I've learnt my lesson!
Been driving since Monday now.
The car goes really really really well - Much better than I expected.
Idle is a bit rough when the car is warm, not too sure what the cause is but I'll check with the tuner when it goes back in for E85 in the coming months.
Diff is just as noisy as I ever remember, booming and clunking quite frequently
With the "flash" rains in Sydney the day before last, I noticed a massive pool of water in my foot well, which has now made the car stink FFS. I need to track this down before it rains again next week.
I'll head out and take some pictures this weekend for those interested. Also going to the Skyline meet tomorrow night and hope to see some of you guys there.
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo :-D
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
