I believe if the block is older than the car it has to meet the emission standards of the model of car its in.
ie it would have to be bone standard and im240 tested etc
doable on e85...but e85 needs an aftermarket ecu....so technically not legal.
is modified...so not legal.
but would they pick it?
it's one of those things Mafs would need to be standard. injectors turbos etc
way to much effort to have a legal rb30....which for it to be legal would make 250kw
so imo build a 2.8 or 2.9
legal in the sense of using the oem block yes.
subject to capacity limits...but not many engieers will ask you to strip and engine to check...especially as it has all the factory numbers.
usually record of capacity is only needed if you were putting a turbo ls1 or something in a 32. where a ls7 7l looks the same as a 4.8l LS truck engine
actually...has anyone checked to see if darton 90mm sleeves could be used.
use a BC or spool 2.9 crank and rods with custom 90mm pistons.
might have to be siamese bore so cooling down the back of the motor might not be great.
would make it a short deck 3015cc RB
I built a Nitto 2.8 stroker and then i sold it.. Iam now starting my Nitto 3.2 stroker build. I would only go with Nitto (for strokers) because they're local and are proven to hold massive power.
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
