Hello,
Will give you guys some background.
R32 GTR - built engine.
I have had this cough nothing major when cruising around the city or on the motorway at low RPM. As soon as it happens (its not even major) it is fine and you can accelerate fine.
It does happen when you start to accelerate.
Have new platinum spark plugs
new spitfire coil packs (did this after i did those before it was built)
HKS F-con pro (latest version)
HKS EBC
Forged blah blah blah.
Now I was thinking it could be the wiring harness to the coils but not 100%.
Like is said there is no miss/cough anywhere accept when you start to accelerate from low rpm and its not even major but it is there.
https://www.sau.com.au/forums/topic/451850-cough-while-driving-at-low-rpm/
Yeah it is at the same load point. So you could be in 4th at 2k rpm. just put your foot down it cough/miss.
as soon as you go past it she's mint and its so brief that it just more annoying than anything.
It has Tomei Poncams in it as well as cam gears.
it still happened before the engine was built and before i had new turbos (-5's).
Did it happen before i had the computer? I couldn't tell you have had it for awhile now.
i believe this sounds like the power fc cough that has been talked about here before...wonder if its similar but with the HKS.... anyway...one of the solutions that worked for some was to fix up and make better all the grounding points in the ingnition harness and ignitor.
Yeah called the tuner he does think it could the ignition harness and ignitor. Ah well might have to replace after all it is 25 years old :)
Other than that the car is running perfect and goes hard.
Thanks for the help much appreciated.
Edited by Stixbnr32
New Nismo Race pump with FPR.
Mine was a new 275 with new FPR! Started out Ok then over a few months started as a very quite and gentle 'choo' type sneeze then slowly got louder. Pump eventually went very noisy so I replaced it and problem solved.
Interesting - the tuner that did it is a native Japanese (used to work for Nismo afaik) and he is HKS certified.
He tunes big power GTR's here in NZ/Aussie (when called) and other big power cars.
It just had a retune after the rebuild and has the same little cough.
I will pop him another call get him to check.
$130us for a WB these days, shipped. Should be pretty easy to see if there is a lean spot on acceleration with one of them mounted in the exhaust. He might not see it as well on the tailpipe wideband.
I have had all kinds of tuning 'faults', that one included. My evo does it on cold start atm, I need to fatten up the cold start map but I will just be wasting fuel I guess.
Spools the turbo extremely well though. The joys of not having to worry about knock. :P
WB is the brand. http://www.wide-band.com/widebandproducts. Looks like the price went up $15 since I bought mine a couple of months ago. I got the tiny display to hide behind the clock.
I get what i think is the same cough in the gtr but haven't really tried anything to fix it yet... Think we had to lean the throttle enrichment a bit might check that as well. It's quite a violent cough sometimes though... Like early rev cut. Cheers for the links.
My E85 cold start makes the 25 brap like a PP 13B for a few seconds.
Decided I'd leave it as is.
But yeah, it the car pops or coughs as soon as you press the throttle, its the throttle pump/accel enrichment
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
