OK helpful advice coming down the pipe.
About the Cam wheel and trigger:
1) The flat head cap screws that the trigger is apparently designed for are near impossible to find. I will be making some myself by machining normal M7 cap screws. The cams have M7x1.00 pitch threads...yes M7x1.00. Should have known when I had to get the 11mm socket out that something was funny. With my Tomei cam gears (and Tomei cams) I needed 43mm of depth for a NORMAL headed bolt to go on. a flat head screws should be similar length...Flat head cap screws are a great idea though because the countersinking will allow more room under the top timing cover (I'll get to that in #3 below). I have attached a picture showing NORMAL BOLTS M7x1.00 (50mm cut down to 43mm length). I also am using the factory plate and added lock washers.
2) Be Prepared to cut your timing cover. Thank goodness I had this gaudy Nitto clear cover and it trimmed out very easily. The sensor still SLIGHTLY protrudes into the flat plane of the cover, but I bet I could lightly file it (1/8" or so). I will be making a new plate to rivet on to my Nitto cover in the shape of the (sorry to say) Alien-head-shaped hole. Again see pictures for clarification. Not much about the design could be changed to rectify this.
3) The bolts from #1 above will definitely break the plane unless I find some flat head (countersunk) M7x1.00 cap screws. I'm telling you they are impossible to find...I'll be making some.
Crank pulley trigger:
1) I have the Tomei oil pump and it's cast differently than the factory oil pump. The pressure adjusting part of the Tomei oil pump makes the installation of the lower trigger impossible. I will have to make another option. Also It looks like my Fluidampr harmonic balancer won't work either. I will be making another tooth and pickup arrangement for my setup, but I kinda suspected that before ordering (and now we know!). Also note in my pictures that the harmonic balancer is not pulled very far onto the crankshaft yet.
Overall very pleased. WE need to find a solution for the cap screws on the cams and I believe this should be included in future kits.
Thanks!!
The lower bracket and Tomei pump issue, no room to machine the bracket out to fit over the pump?
Or does the sensor itself still hit the added oil relief casting on the Tomei pumps regardless of what you do to the bracket its mounted on?
Murrayis,
No sweat. The effort was valiant. As I like to say, "The credit belongs to the gladiator in the arena...not the critic in the stands". You've done great aside from pick an odd ball cap screw that I'll need to probably have machined, but i figure thats more of Nissan's fault than yours. To be fair I figured I was on my own with the crank dampener regardless...now we know. Now we are both gladiators in the arena.
Send me the drawings, I am a mechanical engineer with the ability to get our problems solved and likely cap screws made! What is the bevel angle and diameter?
really impressed. great work. really like the crank trigger setup, as for teh oil pump fitment clearence issues, perhaps thats why other setups are mounted from say the oil pan rail, rathern than the front of the block.
I would be real keen to find out if its possible to create a disk setup that works inside of the stock CAS, essentially keeping it looking stock at the front.
would hate to CUT up a nice set of 26 painted covers.
Great to hear Robert.
Guys and Gals - I am going to do 1 more run with the factory and leave this project as Open Source.
If you want in please let me know as the order has been placed with the factory and they are waiting on confirmation of numbers - With the USD v AUD not looking to improve any time soon the cost is slowly increasing to produce.
Currently there's 15 sets out in the world from Canada to Tasmania all the way to Sweden - I could not be more happy with how this project has turned out.
Cheers
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
