I'm undecided atm on buying at greddy plenum off another sau member. Weighing up whether it will make a $1000 noticeable difference tho or will I still achieve my power goal with the stock plenum. Might as well do it while I have the car with abe so he can make up the new cooler piping.
The plazmaman one gives you a gain of about 8 kilowatts,,,what the front facing ones do though is clean up your engine bay. They make it a lot easier to get at injectors/coils/plugs plus a whole lot of other stuff.
Cheers
Neil.
Yup that's exactly why I changed my mind. $1000 for 8kws doesn't add up to a big enough benefit. Think I might put that money into some areo. Abe will be making me up a front splitter and just need to find a place that sells bee-r rear wing like Richo's.
Dropped the car off at the panel beaters to get some work done. Getting the massive hole from removing the sunroof fixed. Was gunna just patch it up but got talked into cutting the roof off and replacing it with a new one. Also getting getting my GTR wing base installed and painted so I can attach a bee*r rear wing, side skirts installed, BL front lip installed and front bar Resprayed and new front windscreen installed. All up got quoted $3500. Should be finished in a few weeks. So will keep you posted with pics.
Yup it's all happening over the coming weeks. Once finished here it will be sent straight to forced Motorworx and chequered tuning. Can't wait for it to be all finished and I can finally hit the track.
  • 3 weeks later...
  • 4 weeks later...
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
