Okay fine, entered for Sunday. You all had very convincing arguments. Looking at the entry list, I will most definitely be holding up traffic. My car has also just got slower, took out the tune, lost 12rwkw which makes it go from slow to slooooooooooooow. Sorry, and my bad in advance.
Put me down for food Saturday and Sunday Ash, I think I'll head down on Friday and make a long weekend out of it :)
Haha good work Juliette :thumbsup:
Nah, it was occasionally throwing CELs and putting the car into limp mode so I cracked it and ripped it out. Might do it again with a different ECU and tuner at a later date when more mods would make it more worthwhile.
Hey guys, Im a new member this year and I was thinking about coming down for the Saturday to learn the track, I have a stock r33 gtr v-spec what are your thoughts on how the car would perform, is it critical that I do such things as upgrade the oil cooler?
I wouldnt say its esstential, but you won't be able to do as many laps before the oil temps get pretty hot
As long as you have an oil temp gauge to monitor your temps you'll be fine
As a guide on my stock GTT no oil cooler i got about 4 laps at Sandown before oil temps got above 120c
1. Ensure you have oil temp gauge.
2. Ensure you over fill the sump by 1 Litre before attempting track duties.
3. Ensure all other fluids are topped up and good to go
4. If brakes are under 30% pad, fix that up.
5. Ensure you READ the supp regs and sort things out like Fire Extinguisher, Battery point markers etc.
Otherwise you should be good to go. Long term it would be a good idea to sort an oil cooler and pay some attention to better brakes if you've not done half decent pads/rotors as at tracks like Winton you're gonna have a tough time.
There is sooooo much experience in the SAU-Vic track group, it's the best place to come if you want to do some laps in a Nissan. And if there isn't someone that can't answer your questions or help you out, then you've got something really wrong and should probably start worrying :P hahaha
Most all though remember to have fun as that's what it's all about. There are no heros at our events, just a bloody good bunch of guys so make sure you find the banners and come say a g'day.
  • Like 1
It's not an SAU track day without people scrambling to add upgrades and put their car back together in time :D I'll see you guys at a few rounds this year hopefully... won't be at PI though.
sure sure, you said that last year, year b4 and I think maybe the one prior to that...(or was that turbo gasket year)
Ha! you're one to talk Martin...
car saw the track briefly last year, a few early the year b4.
Entered our Motokana this year and waiting for the SAU sandown entries to open...
so to quote this dude who used to turn up to track days
cool story bro.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
