Hi guys
I have these parts for sale, originally was planned to use on my track cars but since both cars have been sold so I need to make room for a new project.
All the parts Are brand new.
Delivery can be arranged.
R32 GTR Jun style carbon lip - $395
R32 GTR Carbon cooling plate - $170
R32 GTR/GTS Nismo Style carbon Trunk Spoiler $280
R32 GTR Carbon Vented head light replace - $250
R32 GTR Carbon Top secret style Diffuser - $580
R32 GTR Carbon side skirt addon - $360
R34 GTR TBO Style Carbon Canard 4 PCS - $240
R34 GTR Carbon Nismo Hood - $750
R34 GTR Carbon Ztune side skirt and rear pod - $700
R34 GTR/GTT Carbon Mirror cover - $110
R34 GTR Carbon (First Lip) - $380
R34 GTR Carbon OEM front diffuser (Second Lip) - $ 430
Also Have some R33 GTR GTS carbon parts for sale
Located south of sydney
PM me if you're interested
Thank you.
R33 parts
R33 GTR carbon jun Style front lip - $420
R33 GTR Carbon top secret style diffuser with metal fittings - $ 580
R33 GTR Carbon rear exhaust bumper heat shield $120
R33 Carbon cooling plate - $210
R33 GTR carbon canard - $ 310
thanks
heres some photos of the parts, i'll take the rest tomrrow.
http://s1303.photobucket.com/user/roy85321/media/20150116_220315_zpsb757bacc.jpg.html?sort=3&o=0
http://s1303.photobucket.com/user/roy85321/media/20150116_220305_zps060d0b12.jpg.html?sort=3&o=1
http://s1303.photobucket.com/user/roy85321/media/20150116_220257_zpse52c325e.jpg.html?sort=3&o=2
http://s1303.photobucket.com/user/roy85321/media/20150116_215501_zps31ef5d14.jpg.html?sort=3&o=3
http://s1303.photobucket.com/user/roy85321/media/20150116_215442_zps98bd16f5.jpg.html?sort=3&o=4
http://s1303.photobucket.com/user/roy85321/media/20150116_214710_zpsa5ac3ed0.jpg.html?sort=3&o=5
http://s1303.photobucket.com/user/roy85321/media/20150116_214657_zps4319c967.jpg.html?sort=3&o=6
http://s1303.photobucket.com/user/roy85321/media/20150116_214214_zpsa600a608.jpg.html?sort=3&o=7
http://s1303.photobucket.com/user/roy85321/media/20150116_214202_zps254391ff.jpg.html?sort=3&o=8
http://s1303.photobucket.com/user/roy85321/media/20150116_213422_zpsaf896c31.jpg.html?sort=3&o=9
http://s1303.photobucket.com/user/roy85321/media/20150116_213409_zps5ce9a98f.jpg.html?sort=3&o=10
http://s1303.photobucket.com/user/roy85321/media/20150116_212817_zps4583ea1e.jpg.html?sort=3&o=11
http://s1303.photobucket.com/user/roy85321/media/20150116_212805_zps16ef9d49.jpg.html?sort=3&o=12
http://s1303.photobucket.com/user/roy85321/media/20150116_212757_zpsbe85c665.jpg.html?sort=3&o=13
http://s1303.photobucket.com/user/roy85321/media/20150116_212047_zps76e98f5b.jpg.html?sort=3&o=14
http://s1303.photobucket.com/user/roy85321/media/20150116_212038_zps81213b01.jpg.html?sort=3&o=15
http://s1303.photobucket.com/user/roy85321/media/20150116_210500_zps53610a63.jpg.html?sort=3&o=17
http://s1303.photobucket.com/user/roy85321/media/20150116_210450_zps0203a69d.jpg.html?sort=3&o=18
http://s1303.photobucket.com/user/roy85321/media/20150116_204414_zps82d6b1fb.jpg.html?sort=3&o=20
http://s1303.photobucket.com/user/roy85321/media/20150116_204402_zps9941ef31.jpg.html?sort=3&o=21
http://s1303.photobucket.com/user/roy85321/media/20150116_202711_zpsf330e819.jpg.html?sort=3&o=22
http://s1303.photobucket.com/user/roy85321/media/20150116_202640_zpsc7d52c22.jpg.html?sort=3&o=23
thanks
  • 2 months later...
  • 3 weeks later...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
