Josh at Forge Performance is helping me out, i want it done properly, especially with the throttle body rework and resealing the plenum properly as well as the hoses.
hes a champ and looks after pricing really well so im happy to use his assistance.
pin hole leak in one of the pipes... it let out sooooo much coolant lol
all fixed.
must say, she does seem to be in good company at FP
1511648_895896273803954_4276019161622516
also... mmmmm sexy wrinkle paint for the plenum
blasted back to bare metal and refinished.
I think the intake side needs greddy hard-pipes and all new metal IC pipes all done the same?
then a deep candy red for the rockers and cam cover, neaten it all up a bit.
the old paint, like all, was cracked and flaking off, looked a bit shitty.
Edited by GH05T
  • Like 1
  • 5 weeks later...
haha,
well picked up a gtr passenger seat last night and i have a fixed bride drivers seats arriving hopefully this week. ill get be a gtr back seat from a mate when i go to the hills next and it will look a bit better.
  • Like 1
lol, i put the passenger seat in yesterday but it needs a good clean, will do as a place holder untill i track down a mint one. more delays in my bride seat turning up but ill have both in soon, Josh at forge is gonna hook me up with a gtr rear too
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
