woohoo cars developed a missfire which rapidly became undrivable when warmed up.
possibly head gasket/ fluid in cylinder type thing...possible coilpacks...possible ignitor.... possibly just the wrong temp air in that part of town...ok now im just hoping for the best.
*BACK TO THE SHOP*
nanananaNANANANAnananana
Edited by GH05T
ok good news. heads fine. coolant looked a bit... off colour so well flush  it and keep an eye on it. you never know their might be an underlying problem but for now she's running sweet again.
im over spitfires and ignitors so I'm now running R35 packs. much simpler. problem solved. cheap outcome is a good outcome.
now back to working out how much to spend on bushes and coilovers.
My vote MCAs.
I went over the top, put MCA reds in my 33, Josh at MCA tuned the valving for me after a chat about what i wanted.
Took all of the sketchness out of bumps on hills roads like up to Lobethal that my old Tiens had. Feels stable in the corners but doesn't jar the spine on Port Road. I'm sure their street options would be just as good, but perhaps give them a call to chat.
They're also perfect for sitting in the garage with engine out too, sigh.
  • Haha 1
  • 1 month later...
odd question, my collant is overflowing normally into the overflow tank when the engin is shut off but its not drawing back in when cooling.
imusing a 1.3kg cap which is the highpreasure cap, is this likley to cause an issue for basic driving? shoudl i revert to the nomral 88kpa cap?
Awesome build!
Sounds like a lifted head or gasket not sealing somehow. To exceed that cap pressure you'd have to really be running that motor hot and I don't suspect you are. A lifted head or bad head gasket seal will push coolant like that at operating temp and pressurize the system. When the motor cools the pressure is still there because it wasn't caused from heat in the first place. Are your rad hoses rock hard after you romp on the car a bit?
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
