Hey all,
Was wondering if any GTR yodas could she'd some light on the subject. Bought a GTR recently and was told the car had upgraded garrets but not sure on size.
Pretty tightly packed on the exhaust side of the gtr as you guys know. I need someone to help me identify what it is I have on the car.
What I do know:
- They have a .64 rear
- has Garrett on the front covers
- noticed a tag that says ARMS on the front cover. Can't see much but on the tag it also says RB and an A engraved/stamped under it. Reallllly tricky to try and get a pic.
Anywhere else I should be looking?
Thanks in advance
https://www.sau.com.au/forums/topic/452970-what-turbos-do-i-have/
http://www.nengun.com/tomei/arms-b7660-turbine-kit-nissan-rb26dett
again without seeing the tag we cant say that these are your turbos as alot of very different turbos look very similar
thanks man...
did some digging and found this...
Tomei B7655 (173011) 47.7 55T 0.42 T25 T25 47.0 76T 0.64 BB ~500PS
Tomei B7660 (173012) 47.7 60T 0.42 T25 T25 47.0 76T 0.64 BB ~600PS
Tomei B9046 (173013) 51.7 46T 0.42 T25 T25 53.6 90T 0.64 BB
~700PS
http://homepage.ntlworld.com/tbroom/Turbos.htm
looks like i will have to remove some stuff to get to the tags to confirm..
Seems as though they are Tomei variants. not finding a lot of info on it. car makes 260kw atw at about 14-15psi. stock ecu.....
Edited by WantGTR
If they are Tomei.
Commiserations... Just search "ARMS" here on the forums and you'll see they are not the best performing twin configuration, they are almost the worst. They are better than factory though in that they wont break. So that's good news :)
  • Like 2
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
